Re: What to do with 74 Challenger Ralley (engine choice)
[Re: Otto]
#2272957
03/20/17 01:34 PM
03/20/17 01:34 PM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
[Re: Otto]
#2273054
03/20/17 03:43 PM
03/20/17 03:43 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Magnum headed 408 Dress to look like a 318. Can even use LA valve covers.
**Photobucket sucks**
[Re: 70Cuda383]
#2273056
03/20/17 03:44 PM
03/20/17 03:44 PM
70Cuda383
Marysville, O-H-I-O
Well built 408 will make an easy 500 hp and be much lighter than a big block. It'll handle way better than a big block, keeping true to the ralley package
[Re: Otto]
#2274461
03/22/17 09:19 PM
03/22/17 09:19 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
completely stock.. all the way to all A/C components in place. Fully painted.. looks nicer than showroom new. Then that answers the question. A completely stock engine bay is very difficult to replace. The fact you are starting with one means it should be retained. LA all the way. ...and I'm into MODIFIED E bodies!!! Even I wouldn't change it.
[Re: Otto]
#2274810
03/23/17 02:48 PM
03/23/17 02:48 PM
Posts: 19 Colorado springs, CO
Arominus
318 with aluminum heads/intake/headers, a decent cam and a beefed up 904 or A500. It would be awesome and light.
1957 Desoto Firesweep 2dr 392/A518 builds in progress.
[Re: Otto]
#2275190
03/24/17 02:18 AM
03/24/17 02:18 AM
Posts: 2,918 Calgary, Alberta Canada
a12rag
So the original 318 for my 70 Sport Satellite was long gone . . . I built a 360 to live in it's place . . . although it looks like a "stock" 318 (with a 4bbl carb though - and air cleaner from 72 340 with big vac operated flap on right rear side) ... I drive my car, and yes it all works - a/c, and cruise control, etc. . . .
As was said, what are you wanting to do with your car ??? You want to go fast, then build whatever engine you want. You want to look stock/go fast, build small block stroker to look like 318. You want to enjoy your car, drive it all over the place, get decent gas mileage, leave the 318 and just drive and enjoy . . . it all comes down to what you want . . . you gotta build the car for you . . . .
Good Luck,
Cheers,
Mark
[Re: Otto]
#2275267
03/24/17 10:29 AM
03/24/17 10:29 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Opinions please.
What would do better on resale when that time comes ? Being it is a 318 Rallye, it is on the fence as to have a better resale with a 318 vs a 440. If it was a 360 Rallye, the answer would be clear, keep it OEM as possible. If it was a standard Challenger, a 440 would likely have a better resale. Although there are buyers that would prefer a 440, I think most prefer OEM or at least an OEM look. If you make any changes, make ones that are easily reversed. If it were mine, I'd pull and save the original drivetrain, pick up another 318, stroke it to 390 and detail under the hood to appear OEM as possible like a12rag's Satellite above.
