Indy rocker adjusters
#227301
02/16/09 09:23 PM
02/16/09 09:23 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I would like a better adjuster for these Indy rockers since the ones that come with them suck but I cant afford mantons so what else are out there. Thanks
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Indy rocker adjusters
[Re: dusturbd340W5]
#227303
02/21/09 10:24 PM
02/21/09 10:24 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Why do they suck? I am curious since we have a set coming?
[Re: cl440]
#227304
02/22/09 12:03 AM
02/22/09 12:03 AM
dusturbd340W5
Kissimmee Fl.
tiny little hex to adjust with 1/8 allen and the holes for the allen are sloppy from the start doesn't fit.You can not keep the adjuster from turning when trying to tighten the lock nut just to small of a wrench.
[Re: dusturbd340W5]
#227305
02/22/09 12:04 AM
02/22/09 12:04 AM
dusturbd340W5
Kissimmee Fl.
Smith Brothers is the only ones I found that had a 3/8x24 adjuster that used a 3/16 allen.
[Re: dusturbd340W5]
#227306
02/22/09 12:19 AM
02/22/09 12:19 AM
Posts: 1,633 Jacksonville, NC
RonP
Jacksonville, NC
Yes they are the worst allen sockets I have ever seen. SO sloppy. A few years ago I bought a set of adjusters for my indy rockers from Scott Brown that were much better. I have no idea who made them though.
[Re: John Burdine]
#227308
02/28/09 10:29 AM
02/28/09 10:29 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
do you have a part# for these?
I had ordered a set of smith bros to replace the adjusters on my crane golds that we were going to use in my wife's motor. Ended up using the indy sr out of my motor in her's. The smith bros adjusters I got for the cranes worked just fine in the indys. Don't have a part number, but it's as simple as a phone call to smith bros. They'll know what you need.
[Re: dusturbd340W5]
#227309
02/28/09 11:39 AM
02/28/09 11:39 AM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Perhaps they are metric?
[Re: moparmanjames]
#227310
02/28/09 12:59 PM
02/28/09 12:59 PM
dusturbd340W5
Kissimmee Fl.
nope tried that to nothing metric even close they just suck. lol
[Re: dusturbd340W5]
#227311
02/28/09 02:26 PM
02/28/09 02:26 PM
Did you have any other problems with the IndyBrock heads. I just bought the same heads (full CNC port with the bigger valves) and the quality of everything sucked. Did a vacuum check and they failed. Valve to valve seat was off as much as .006. Valve guide clearances were as high as .0045. They did not use hardened shims under the springs, they were soft. The exhaust valves were .043 shorter then the intake valves. The worst part was the flow check. They claimed they flow 304 cfm at .600 lift on the intake and mine only flowed 283cfm.
[Re: dusturbd340W5]
#227312
02/28/09 02:33 PM
02/28/09 02:33 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
mine too just junk!!!
[Re: dusturbd340W5]
#227313
02/28/09 02:35 PM
02/28/09 02:35 PM
Dodgem
Ontario, Canada
me too they just suck!! So smith brothers. I got a good set of used HS but need new shafts $200???
[Re: Dodgem]
#227314
02/28/09 03:27 PM
02/28/09 03:27 PM
dusturbd340W5
Kissimmee Fl.
My heads went from Indy strait to RyanJ and had him do a VJ and a little clean up on the runners also put the correct springs for my cam so I didnt have any of those problems according to Ryan OTB they flowed 305 intake and 214 exhaust @ 700 after he was done with them they went 314 and 230 @700.
