Re: 42RH rebuild kit, which to get?
[Re: roadrunninMark]
#2272765
03/20/17 03:05 AM
03/20/17 03:05 AM
RapidRobert
here just was a thread on where to go & iirc it said transparts & rockauto (not much but a BTT for you). EDIT yes it was likely "transtar" that I was trying to recollect.
#2272909
03/20/17 12:25 PM
03/20/17 12:25 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I have used several of the Transtar Super Deluxe kits. Used their kit for a 42RH ...12008E can be purchased at Northern Auto Parts for 116.00...
Also used their kits on several 46RH and 46RE.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
#2272934
03/20/17 12:59 PM
03/20/17 12:59 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I'll second Transtar for a kit, I was able to buy directly from their local to me supply house.
#2273287
03/20/17 09:53 PM
03/20/17 09:53 PM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Are you looking for the cheapest or one with better parts AND recommendations?
If you want quality parts along with recommendations on which parts to go with, then call A&A. They will be higher than the off-the-shelf kits, but they will talk to you about your particular application and guide you to the right parts......the first time.
Master, again and still
#2274294
03/22/17 04:01 PM
03/22/17 04:01 PM
JohnRR
U.S.S.A.
Looking for the best rebuild kit, replacing plastic hardware with metal. I will look into A & A. What PLASTIC hardware ?
#2275649
03/24/17 11:21 PM
03/24/17 11:21 PM
Posts: 2,943 GA
roadrunninMark
GA
Hey John, I was reviewing a thread on the jeep forum for the rebuilding the trans. I could have sworn I read a piece where the author talks about replacing a plastic washer with a metal one. I will attach a link to the thread, but now I cannot find the part with the plastic washer. It may be in there, then again, I could have read it somewhere else? Anyway, here is the link..... http://www.jeepforum.com/forum/f13/46re-tutorial-911009/Oh, I found it! Post #5 when the author talks about the drum the low band runs on... Ever hear of SONNAX brand of parts?
