Re: Real world weight loss program and it` cost..........
[Re: hemi-itis]
#2272482
03/19/17 06:19 PM
03/19/17 06:19 PM
fullmetaljacket
He means the cat walk section running along the whole brim. Just has to be welded well and shut. Grounded smooth after that, it becomes more beautiful and wind slick. Probably a few pounds right there. The spot welds that held that portion together was shoddy at best from the factory. I would jig and or clamp the cars front longitude together while you cut to keep things straight and level.
[Re: hemi-itis]
#2272541
03/19/17 08:35 PM
03/19/17 08:35 PM
Posts: 1,295 Tucson AZ,
MadMopars
Tucson AZ,
You planning on tying the outside of that steering box support back into the K frame? -Trent
[Re: Thumperdart]
#2272640
03/19/17 11:11 PM
03/19/17 11:11 PM
Posts: 9,881 MI, usa
dvw
MI, usa
[Re: MadMopars]
#2272748
03/20/17 02:32 AM
03/20/17 02:32 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
You planning on tying the outside of that steering box support back into the K frame? -Trent Will be moving the steering box over toward the rail.I'm also told to cut the flanges on the "k". Engine parts should start showing up this week It seems the "c" channel I used to raise the engine plate was distorted for some reason,,,,,,,,,,,,,,
[Re: Thumperdart]
#2272935
03/20/17 01:01 PM
03/20/17 01:01 PM
hemi-itis
Doug,did you use the original steering box mount or did you install a new plate? I think I will use the original AMERICAN STEEL that is there, clean it up after moving the box and reinforce.
[Re: Thumperdart]
#2273422
03/21/17 12:55 AM
03/21/17 12:55 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Dvw, those steering box bolts are WAY too long... haha
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Thumperdart]
#2273480
03/21/17 02:25 AM
03/21/17 02:25 AM
hemi-itis
As much as I would like to duplicate what Doug did with his "K",It would be harder to do in the car.I was also surprised at the mere 2 lbs that chunk was that was cut outta my k.The amount of work to remove the flanges and weld everything back up will not be done or the 3 or 4 lbs net.The aluminum heads with stands should be 85 to 90 lbs.An aluminum radiator should be at least 20 lbs,,,,whaddia think?
[Re: dvw]
#2273720
03/21/17 03:34 PM
03/21/17 03:34 PM
OUTLAWD
Metro Detroit
Your car is so clean...pretty sure the paint on your K-member is better than the paint on my hood.
