Anyone here running Q16?
#227250
02/16/09 09:13 PM
02/16/09 09:13 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Just like it says. I am considering the switch to Q16 from C14+. Just curious if anyone else had and what their experiences were. Yes I have read all the propaganda, just curious if anyone here has any personal experiences.
Re: Anyone here running Q16?
[Re: Al_Alguire]
#227251
02/16/09 09:24 PM
02/16/09 09:24 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I've used it, dyno tested it, I sell it(VP Fuels dealer). The feedback I have been getting is spotty. In almost every case it was worth power. A mountain of power-no, but it's worth some nonetheless. It reeks, and is so aromatic that it will make you ill if you are in an enclosed area(dyno cell with the fan off). Obviously the tune up is very critical and no two engines respond the same way. If you get the tune up right you will see a gain. It's also important to purge the lines after a race. Some have reported failure of fuel lines due to the fuel, so you have to take that into consideration as well.
The consensus is that in a class that has limitations, it might be worth the time and effort. Otherwise, there are easier ways to find a tenth or so.
MB
[Re: Al_Alguire]
#227254
02/16/09 10:04 PM
02/16/09 10:04 PM
Posts: 1,624 Orange County, Ca.
B1CUDA
Orange County, Ca.
Al, When I had that motor, it crossed my mind, but, I had way more negative feedback when I was asking about it. I figured I would stick with what was working.
P.S. I have 15 gallons of C14+, that are useless to me, as my new motor did not like it at all. If you want me to bring it to MATS, say the words, and the stuff will be delivered.
[Re: B1CUDA]
#227257
02/17/09 12:59 AM
02/17/09 12:59 AM
Al_Alguire
Las Vegas
Chris-I might just take you up on that since we know it works. I talked to Jason about it and he was all for it. He said he has seen 25-40hp increase using it on the dyno. We discussed jetting etc and came to the consensus that it was a good move. BUT I have heard so much negative stuff about it I have been reluctant to pull the trigger. But I need to buy fuel and that is what spurred the call.
Well that and some other stuff. He also gave me his thoughts on my converter issues. We agree I need to go even looser than the 6800 stall piece I have in it. So looks like my old loosey goosey one goes back in. Car ran it's best et for me with it in there, so after trying two other custom built pieces back to ole faithful which is still tight for the motor.
Sean was your experience on a nitrous motor or an N/A deal? I was told it did not contain methanol but was highly oxygenated instead. I dont have an issue with draining it as we do that already. Thanks for the input that is what I am looking for.
DT I would not mind trying to go with E85 but it is pretty much non existent here. My compression is just over 15-1.
Chas-Cost is not a factor. It is the saem cost as the C14+ for me. As for the smell, the C14+ is not exactly pleasing to the nose. In fact I dont even like loading the car with the engine running any more, it will give me a headache. So I cannot imagine the Q being much worse.
I am not necessarily after every little .03 in ET. It would be a welcome side affect if it happens. I was interested in it more from the repeatability aspect and it's ability to not change as drastically with swings in DA. Looking at it more from a bracket standpoint then ultimate ET.
[Re: Al_Alguire]
#227261
02/17/09 10:53 AM
02/17/09 10:53 AM
Posts: 573 PA
68CudaB1
PA
We used it all last year, seemed to work good...we started with Q16, so we dont have any comparisons.....16.5:1 motor One thing we liked about it.....it really burns clean, pistons and chambers were really clean. We are sticking with it
[Re: 68CudaB1]
#227262
02/17/09 11:16 AM
02/17/09 11:16 AM
Al_Alguire
Las Vegas
As I stated earlier the cost is not a factor. The price for the Q16 is the same as the C14+ I currently use so cast wise it is the same.
Sean I think the big difference between my motor and most B1's is that mine is a short stroke big bore deal. Mine is a baby compared to most. Reminds me more of my first one which was a 451" one. Just for a little backround I had a custom built piece in it that would not stall past 4600. On shifts it dropped to 5500 and my motor does not make much power at all there. The current, custom built converter is stalling at 6800 and is dropping to 6600 on the shift. I need something looser. I have one a buddy ran in his top sportsman car that has worked better than any other one that has been in the car so it looks like I may just put it back in, 15% slip at the stripe and all. I ran quicker ET's and better MPH with it.
Bob-Yes the Jason I refer to is Jason Pettis. Like I said I am looking at it from a repeatability standpoint. Any ET gain is just gravy. It cost me the same as C14+ so I was figuring if I can gain even more consistency over a wide DA range then why not. We do get big swings here at times during a day of racing, especially in the summer.
[Re: Al_Alguire]
#227263
02/17/09 07:11 PM
02/17/09 07:11 PM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
Al, I have run Q-16 also,and the motor seems to like it,it was faster at the track.I dont have dyno numbers to compare..I was running C-25 and had to jet up 6 to 8 jet sizes when switching to Q-16.It does burn real clean,but would recommend draining after your done at the track,and don't store it in plastic containers,leave it in the metal containers..or drums..It does stink,but all VP fuels do..
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: Al_Alguire]
#227264
02/17/09 07:19 PM
02/17/09 07:19 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I ran Q16 all last year. It was worth a tenth with my 1050 carb. I never could use it with my bigger 1150 carb because I could not get enough fuel jet at the time I was testing.
I did have a fuel line failure it rotted from inside out. I mentioned it on here and don't remember anyone else reporting such a problem.
I ran C14, C19, C25 and Q16. Q16 being the fastest but the biggest headache. The fastest fuel I have ran in the engine to date was Torco 118NOS which is not made for running NA but worked for my combo.
Leon
