FIberglass hood springs which ones? #2271130
03/17/17 01:23 PM
03/17/17 01:23 PM
Alberta
Wookie316 Offline OP
Alberta
Hi
I have a fiberglass cowl hood coming for my 71 Charger. What springs would be best to use? Will the Harwood GM ones work? What tension since a 71 hood isn't small. Would like to buy from Summit since I'm in Canada. Thanks guys.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271154
03/17/17 02:00 PM
03/17/17 02:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I didn't want to chance the hood warping and decided to make a cheap prop rod, instead of even using light springs.
Re: FIberglass hood springs which ones? [Re: BradH] #2271160
03/17/17 02:13 PM
03/17/17 02:13 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I used springs off a Daytona or similar small car from junk yard, $15.
Don
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271187
03/17/17 02:56 PM
03/17/17 02:56 PM
Ohio
lockjaw-express Offline
Ohio
I have made mine with garage door springs...they make different weight springs, and Ace Hardware is where I got mine. Worked great!
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271192
03/17/17 03:07 PM
03/17/17 03:07 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Originally Posted By Wookie316
Hi
Ooops I was talking for an A body. Guess I should've read your post a little better?
Don
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271229
03/17/17 04:13 PM
03/17/17 04:13 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
There used to be a guy on here selling springs for fiberglass hoods. I think his name was atomic dog?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271231
03/17/17 04:15 PM
03/17/17 04:15 PM
Alberta
Alberta
I may do a prop rod as well since the hood is so darn long. Not sure if there is a spring that will hold it up without too much tension when closed.
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271254
03/17/17 05:18 PM
03/17/17 05:18 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Part of the decision is how stiff is the hood where the spring attaches. Unless it's specifically reinforced (extra layer, thin plate etc.) for a spring anything but a really light spring will bow it.
Boffin Emeritus
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271314
03/17/17 07:05 PM
03/17/17 07:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I wouldn't use a spring at all, puts too much stess on the 'glass. Check this out:
Re: FIberglass hood springs which ones? [Re: Wookie316] #2271714
03/18/17 12:40 PM
03/18/17 12:40 PM
Alberta
Alberta
Thanks. That's what I'm going to do. Great idea.
