FIberglass hood springs which ones?
#2271130
03/17/17 01:23 PM
03/17/17 01:23 PM
Posts: 326 Alberta
Wookie316
Alberta
Hi I have a fiberglass cowl hood coming for my 71 Charger. What springs would be best to use? Will the Harwood GM ones work? What tension since a 71 hood isn't small. Would like to buy from Summit since I'm in Canada. Thanks guys.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: FIberglass hood springs which ones?
[Re: Wookie316]
#2271192
03/17/17 03:07 PM
03/17/17 03:07 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Hi I have a fiberglass cowl hood coming for my 71 Charger. What springs would be best to use? Will the Harwood GM ones work? What tension since a 71 hood isn't small. Would like to buy from Summit since I'm in Canada. Thanks guys. Ooops I was talking for an A body. Guess I should've read your post a little better? Don
[Re: Wookie316]
#2271229
03/17/17 04:13 PM
03/17/17 04:13 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
There used to be a guy on here selling springs for fiberglass hoods. I think his name was atomic dog?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: Wookie316]
#2271231
03/17/17 04:15 PM
03/17/17 04:15 PM
Posts: 326 Alberta
Wookie316
Alberta
I may do a prop rod as well since the hood is so darn long. Not sure if there is a spring that will hold it up without too much tension when closed.
[Re: Wookie316]
#2271254
03/17/17 05:18 PM
03/17/17 05:18 PM
Posts: 4,209 New York
polyspheric
New York
Part of the decision is how stiff is the hood where the spring attaches. Unless it's specifically reinforced (extra layer, thin plate etc.) for a spring anything but a really light spring will bow it.
Boffin Emeritus
[Re: Wookie316]
#2271714
03/18/17 12:40 PM
03/18/17 12:40 PM
Posts: 326 Alberta
Wookie316
Alberta
Thanks. That's what I'm going to do. Great idea.
