Re: Valley Pan Paint
[Re: parksr5]
#2271534
03/18/17 01:55 AM
03/18/17 01:55 AM
RapidRobert
there are no stupid questions. I would without a doubt paint it seperately & not get paint on the port openings relying instead on my choice of gasketing/sealer for sealing there. As you know std paint prep (prep is 90% of a successful job) & picking the correct paint/primer etc as needed (I ain't a painter).
[Re: parksr5]
#2271625
03/18/17 10:03 AM
03/18/17 10:03 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
No paint on the ports.Since the 60s Ive never used paper on any intakes aluminum or iron.Just a bit of silicone in the 4 corners and a bit under the frt and rear hold downs.Never any problems.Rocky
Chrysler Firepower
[Re: parksr5]
#2272032
03/18/17 10:19 PM
03/18/17 10:19 PM
RapidRobert
I would mockup & check the bolt hole alignment cuz with deck height tolerances stackup plus past milling You may need the gaskets just for best/correct alignment fitment (.015 and .030 are available).. Myself I prefer em for sealing but like Stump said many people including Ma did not use em (& even reused em) & have no issues.
[Re: parksr5]
#2272230
03/19/17 11:13 AM
03/19/17 11:13 AM
Posts: 8,866 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Somewhere I recall, Ma Mopar practiced this same tactic at one time. Not positive I am remembering correctly You are correct.
[Re: stumpy]
#2272261
03/19/17 12:03 PM
03/19/17 12:03 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
There are also a bunch of guys that never used the paper gaskets and never had a problem. I'm one of them. Same here.
[Re: parksr5]
#2272379
03/19/17 03:05 PM
03/19/17 03:05 PM
therocks
Niles , Ohio
Since the 60s Ive never took apart a factory intake that had paper.All were just the pans.Rock y
Chrysler Firepower
[Re: therocks]
#2272415
03/19/17 04:27 PM
03/19/17 04:27 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Since the 60s Ive never took apart a factory intake that had paper.All were just the pans.Rock y Four in a set and they are not paper,what do you suppose these are for ?
[Re: parksr5]
#2272440
03/19/17 05:21 PM
03/19/17 05:21 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Since the 60s Ive never took apart a factory intake that had paper.All were just the pans.Rock Well the key word there is "factory" ... no paper gaskets used with iron intakes BUT Ma Mopar recommended them for ALL aluminum intakes. I suspect factory aluminum six packs would have had them.
[Re: parksr5]
#2272839
03/20/17 10:17 AM
03/20/17 10:17 AM
therocks
Niles , Ohio
Ive run aluminum intakes since the 60s.Never a problem with just tins.My 440 now runs both heads and intake.Just tins no paper.been that way for at least 10 years.Rocky
Chrysler Firepower
[Re: Stanton]
#2275499
03/24/17 06:27 PM
03/24/17 06:27 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Since the 60s Ive never took apart a factory intake that had paper.All were just the pans.Rock Well the key word there is "factory" ... no paper gaskets used with iron intakes BUT Ma Mopar recommended them for ALL aluminum intakes. I suspect factory aluminum six packs would have had them. I have restored and owned several 69 1/2 road runners and bees. None have had anything but metal pan.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: stumpy]
#2275538
03/24/17 07:29 PM
03/24/17 07:29 PM
Posts: 955 Chicago
PurpleBeeper
Chicago
They are included in case the heads or block have been shaved and are no longer in stock specs. With a stock set up Ma Mopar didn't need any paper gaskets and neither should you. Actually, if you shave the block & heads the paper gaskets won't even fit..... ask me how I know. I have run them WITHOUT the valley pan (I cut it so the metal around the intake ports is gone) & silicone the edge of the pan to the heads. I may be doing that again this summer.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2275686
03/25/17 12:02 AM
03/25/17 12:02 AM
Posts: 4,669 Wichita
GY3
Wichita
I have always used just the tin itself with cast iron heads with cast iron intake, aluminum intake and aluminum heads with aluminum intake. I did have to "port" the tin to match the cnc port work of my stealths. I use a little Permatex Right Stuff around each port. Never an issue....other than when my dumb a$$ torqued it down with the oil pressure wire under it! LOL!
