Re: drill alignment holes in door hinges ??
[Re: Stanton]
#2270729
03/16/17 07:32 PM
03/16/17 07:32 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Which ever half of the hinge that you are going to remove/unbolt. Maybe both into the door, and into the frame, if you want to. And yes, top and bottom hinges.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Stanton]
#2271162
03/17/17 02:16 PM
03/17/17 02:16 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Are your doors aligned really well now? Are you going to rebuild the hinge bushings?
If yes & no, and you aren't repainting it; you can also use a Sharpie to mark the hinges and get pretty darn close to the way it was. Probably as close as drilling holes in your car if you are careful. Carb cleaner will remove the black ink when done.
Can you knock out the hinge pins and leave the hinges bolted to the car?
Just some things to ponder, Stanton.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Stanton]
#2271316
03/17/17 07:05 PM
03/17/17 07:05 PM
Posts: 9,848 MI, usa
dvw
MI, usa
I'm no professional, just a home garage guy. Line up the new door. Add weight in the door to simulate the regulator,glass and trim. Temporarily install the weatherstrips you intend to use. Then drill. Makes it easier when it's all painted. Less chance of parts hitting. You'll still have to move it a little. Take your time until you get the results you like. Doug
