Re: Differences between 70's and 1991 360 block
[Re: Adam71Charger]
#2271266
03/17/17 05:43 PM
03/17/17 05:43 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
yes..the heads and everything will change over..the 91 block is still a LA block but has provisions for the Factory OEM hydraulic roller lifters and roller camshaft.
The flat tappet cam can still be used.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Adam71Charger]
#2271273
03/17/17 05:57 PM
03/17/17 05:57 PM
Posts: 3,378 KY USA
mopargem
KY USA
There is a provision for the lifter retainer bracket or whatever you call it . also pay attention to your oiling system up top with your head you have to use the right combination of pushrods and rocker arms when changing to a flat tappet as I recall.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: cudaman1969]
#2271437
03/17/17 10:49 PM
03/17/17 10:49 PM
RapidRobert
Yes there was a brief year or two (iirc) transition period (or 2) on the blocks inbetween the std 70'80/90's LA blocks and the 93/94 mag blocks regarding the oil passages on either valley wall (maybe present but not drilled) the guys here know cuz I've read it prior. that is the main caveat, & if you do use the LA heads & there are no passages you can easily external oil them. EDIT With more thought, there might be something different in the roller/non roller cam situation. Hang loose, some one will help us (iirc it was Scratchnfotraction who is up on the ins and out of em.
[Re: Kern Dog]
#2271494
03/18/17 12:36 AM
03/18/17 12:36 AM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Why not keep the heads? Magnum heads outflow almost every LA head by a fair margain. Also, if you plan to use headers with the "Magnum" series block, take note of the extra casting nubs on the sides of the block just below the decks. These interfere with the header pipes and don't allow the flanges to sit flush against the heads. Maybe mock it up out of the vehicle? I don't have a magnum engine, my 360 is one of the last years of the LA block and I don't know if it has the correct oiling setup 4 Magnum heads. Plus I'm not familiar with Magnum heads or pedestal rockers which I know wouldn't be too difficult to figure out. I guess I'm just more comfortable using head I'm more familiar with and that have more intake options. I'm not sure but I think I can pick up a pair of cheap 452 heads and get them cleaned up and some minor port work done cheaper then I can buy a set of Magnum heads. I know the Magnum heads have issues with cracking and I'm more confident that I can find a set of used older heads that don't have cracks. The only thing that I'm somewhat worried about is the exhaust ports in my current heads being in a different position then the older heads which might make finding headers that fit in my truck more difficult
[Re: Adam71Charger]
#2271518
03/18/17 01:29 AM
03/18/17 01:29 AM
70AARcuda
las vegas
Cool. What do you mean by provisions? Are the lifter bores larger? 3 bolts down the center of the lifter gallery that holds the spider in place that hold the dogbones in place that hold the hydraulic roller lifters in place.
Tony
[Re: Adam71Charger]
#2271521
03/18/17 01:33 AM
03/18/17 01:33 AM
RapidRobert
I think I can pick up a pair of cheap 452 heads and get them cleaned up and some minor port work done cheaper then I can buy a set of Magnum heads. A reminder, the 452 heads are BB heads
[Re: RapidRobert]
#2271526
03/18/17 01:40 AM
03/18/17 01:40 AM
Adam71Charger
I think I can pick up a pair of cheap 452 heads and get them cleaned up and some minor port work done cheaper then I can buy a set of Magnum heads. A reminder, the 452 heads are BB heads You're totally right I just realized that after my last post. What la heads are the best bang for the buck? Come to think of it, does anyone know the casting number of the heads that came on a 91 360? Are they better design than previous years? Maybe I can just get them worked on instead of getting different heads, if the intake bolts hole positions are the same too then I could use an eddy intake
[Re: Adam71Charger]
#2271529
03/18/17 01:48 AM
03/18/17 01:48 AM
RapidRobert
I think the 308's are the best iron with (iirc) the 915's 2nd (& there is a BB 915 head). Both are LA. Mags are better but need different parts/some adaptations
[Re: Adam71Charger]
#2271788
03/18/17 02:46 PM
03/18/17 02:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
91 360 heads, swirl port and open chamber, meh.
[Re: Supercuda]
#2271823
03/18/17 03:48 PM
03/18/17 03:48 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Right now Jeg's is offering a good deal on new EQ Iron heads (Magnum Style) for $500.00 and change assembled each. Or if you want to stay with the LA style, there is a pair of freshly machined "915" SB heads on the Tacoma CL for $700.00.....your choice.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
