Specifically the cab, but, is everything compatible to switch from '94 to 97 onto the '98 to 2001's?
Found a rust-free '94 and would like to use all the dash, seats, etc. from a 2000.
Is the frames (bolt holes, wiring, brake lines) the same too? Have access to 2000 4wd running gear and like to make the '94 into 4wd with it.
Mo' Farts
Moderated by "tbagger".
