Re: CLEAR THE AIR ON SB HEAD CHOICE
[Re: fast68plymouth]
#2276517
03/26/17 02:46 PM
03/26/17 02:46 PM
Posts: 1,784 PA
W5DART66
PA
Sooooo, from the block on up, not including the carb(we'll say everything between the block and the carb)...... That would be more or less than 6k?
Impressive numbers!!
What kind of dyno? I'm not used to seeing the print outs in .1 second increments. 😂 6k don't even get close. DYNO-mite dyno.
[Re: Silver68RT]
#2276528
03/26/17 03:10 PM
03/26/17 03:10 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Are the BPE heads available in a 48 degree version? I bought a 48 degree R block in January, and I need some heads for it. I was thinking about the Indy 360-1, or -2, but I've heard bad things about customer service there. It's also a custom order to get them modified for the 48 degree block, and I think it's an extra $1100.
Are there any other options for 48 degree heads besides finding a set of old W2's? I'd like to build a street/strip stroker that I could put in my '69 Dart GT and take on Drag Week. Thinking about something in the 408 - 426" range, NA.
Thanks, I'll check out the W9's. They sounded kind of exotic as far as the water manifold and valve train, and coming without valve seats and guides so I hadn't really considered them. I'm assuming they would require custom headers too. I think TTI makes an A-body header for W2's, and I see that Jeg's still sells a W2 head for 48 degree blocks. I only paid a grand for the R-block, it's an early one without the extra bolt holes for the head, and it's not siamesed bore, 9.6" deck.
The W9's might be overkill (or budget kill) for me. What can you get out of a set of ported W2's on a pump gas 408? I've got 11 cars, so I have to kind of spread the funds out a little. The Dart's current 360 has pushed it to a 13.42 @ 100 mph best, but it's pretty tired now, hence the R-block purchase. I'd like to get it in the low 10's so I'd have a chance at qualifying for Street Machine Eliminator if I went for that class.
So, You have 11 cars, I feel your pain, as I have 9 in total. you have a 13 second 360 powered 69 Dart. You have a 48 degree non-siamese R-3 block. You want an NA street/strip stroker small block in the 408-426 range that will push a street driven Dart to low 10's, but don't feel W-9's will fit the budget, and have asked twice about W-2's. Before you pursue this any further, serious consideration should be given to adjusting the budget, or your expectations. I know they have made 48 degree W-2 heads but they are pretty rare.
I would check with Ryan Johnson at Shady Dell Speed Shop about Indy options. He is a dealer and can do any mods you might like. I would never recommend anyone deal directly with Indy.
Ryan did an engine for a guy on Drag Week that I think was a 48 degree R-3 with Indy heads and it was very quick. I am not sure what rockers were on it. It was a pristine light green Demon. His first name was Paul, last name escapes me right now. I don't think he is on this board but if so maybe he will speak up.
One down side for some folks on the W-9s is that I think Jesel and T&D are the only rockers available. However great stuff.
Good luck!
Bill This is an article on the engine build for the car Bill is referring to in his post. http://www.dragzine.com/news/video-428ci-pump-gas-small-block-mopar-built-for-drag-week/Compare it to MattW's W-9 Build. http://www.hotrod.com/articles/this-436ci-small-block-mopar-makes-big-power-on-pump-gas/Then Check out Mike Crow's 420 Ritter aluminum block build for his 69 5 Speed Dart. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2116453/1.htmlBill's son Clark (Bad340fish) has a 408 W-2 combo that has completed Drag Week, and is currently in the 10.80-90 range in his Barracuda. My buddy Darryl went 11.00-11.20's in his 69 Dart with a W-2 408 and completed two Drag Weeks. Both of these are full interior, real deal street cars, and both engines featured roller cams, and quality component throughout. My 62 Valiant averaged 10.54 for five days on Drag Week, NA with a 428 conventional head, solid ft cam combo, but I'm 300+ pounds lighter than the typical 67-76 A body. Crow's Dart runs low 10's, and would easily be high nines with an automatic, but he continues to try and go fast with a stick, in a small tire stock suspension class. Paul's Demon has been 9.70s-9.80's on his two completed Drag Weeks. What am I trying to say? I spent 10K on my engine, and I already had the block, rockers, valve covers, oil pan, and headers. I'm quite sure the 408 W-2 roller cam combos weren't any cheaper. Stepping up to the MattW/Mike Crow/Paul Cornman type small blocks would be nearly double, I would bet.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: killermopar]
#2276549
03/26/17 03:37 PM
03/26/17 03:37 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I have a set of w2 heads. On top of a 11.5-1 408, with a .590 MP cam it ran 10.40s with ease. In a car that could be used to complete Drag Week? In other words.......... Streetable gearing and converter? Closed exhaust? Before you pursue this any further, serious consideration should be given to adjusting the budget, or your expectations. A quick search revealed 2 sources selling 48* W2 heads P5007445AB for about $400/ea bare. Ultimately, I think this is going to be the least expensive way to get into a 48* top end. Off the top of my head, I'd say that with the basic machining needed, and "middle of the road" hardware, some minor porting....... You'd still easily spend somewhere in the $2500 range to have a set of ready to install heads. Then you still need rockers, intake, valve covers, W2 headers.
#2276590
03/26/17 04:36 PM
03/26/17 04:36 PM
Posts: 1,784 PA
W5DART66
PA
[Re: A/MP]
#2276630
03/26/17 05:26 PM
03/26/17 05:26 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
From 12's to 7's in 10 days. A new Moparts record. Started out as a 2500 dollar post to a well over 15000 dollar build. LMAO.
[Re: MoparBilly]
#2276650
03/26/17 06:15 PM
03/26/17 06:15 PM
Posts: 87 Michigan
Silver68RT
So, You have 11 cars, I feel your pain, as I have 9 in total. you have a 13 second 360 powered 69 Dart. You have a 48 degree non-siamese R-3 block. You want an NA street/strip stroker small block in the 408-426 range that will push a street driven Dart to low 10's, but don't feel W-9's will fit the budget, and have asked twice about W-2's. Before you pursue this any further, serious consideration should be given to adjusting the budget, or your expectations. This is an article on the engine build for the car Bill is referring to in his post. http://www.dragzine.com/news/video-428ci-pump-gas-small-block-mopar-built-for-drag-week/Compare it to MattW's W-9 Build. http://www.hotrod.com/articles/this-436ci-small-block-mopar-makes-big-power-on-pump-gas/Then Check out Mike Crow's 420 Ritter aluminum block build for his 69 5 Speed Dart. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2116453/1.htmlBill's son Clark (Bad340fish) has a 408 W-2 combo that has completed Drag Week, and is currently in the 10.80-90 range in his Barracuda. My buddy Darryl went 11.00-11.20's in his 69 Dart with a W-2 408 and completed two Drag Weeks. Both of these are full interior, real deal street cars, and both engines featured roller cams, and quality component throughout. My 62 Valiant averaged 10.54 for five days on Drag Week, NA with a 428 conventional head, solid ft cam combo, but I'm 300+ pounds lighter than the typical 67-76 A body. Crow's Dart runs low 10's, and would easily be high nines with an automatic, but he continues to try and go fast with a stick, in a small tire stock suspension class. Paul's Demon has been 9.70s-9.80's on his two completed Drag Weeks. What am I trying to say? I spent 10K on my engine, and I already had the block, rockers, valve covers, oil pan, and headers. I'm quite sure the 408 W-2 roller cam combos weren't any cheaper. Stepping up to the MattW/Mike Crow/Paul Cornman type small blocks would be nearly double, I would bet. Thanks for the info, I've seen a few of those articles before, and they are part of the reason I started going down the small block road instead of my original thought of putting a big block in it. I plugged some numbers into some drag racing calculators, and it looks like if my Dart currently weighs 3500 pounds with me in it, it's probably making 275 hp. It's all steel, full interior, roll bar, frame connectors, always ran through the mufflers. Getting to 10.00 @ 135 mph would take 670 hp, call it 700 hp to be safe. Sounds like a ported set of W2's could possibly get me to 550 hp on a 426" SB. Add a 150 shot of nitrous to hit the low 10's? Or bite the bullet and pay up for some CNC ported W9's and everything that goes along with them. Might still go that route. I realize that it's not going to be cheap, just trying to maximize bang for the buck.
#2276674
03/26/17 07:00 PM
03/26/17 07:00 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I have a set of w2 heads. On top of a 11.5-1 408, with a .590 MP cam it ran 10.40s with ease. In a car that could be used to complete Drag Week? In other words.......... Streetable gearing and converter? Closed exhaust? Before you pursue this any further, serious consideration should be given to adjusting the budget, or your expectations. A quick search revealed 2 sources selling 48* W2 heads P5007445AB for about $400/ea bare. Ultimately, I think this is going to be the least expensive way to get into a 48* top end. Off the top of my head, I'd say that with the basic machining needed, and "middle of the road" hardware, some minor porting....... You'd still easily spend somewhere in the $2500 range to have a set of ready to install heads. Then you still need rockers, intake, valve covers, W2 headers. Which bring up a good point. cast iron and starting to get like hens teeth! If your going to go down this route IMO it would be cheaper the embrace the G3 platform. But once again just my opinion.
[Re: Silver68RT]
#2276700
03/26/17 07:42 PM
03/26/17 07:42 PM
MoparBilly
Phoenix, AZ
Now, if you are ready to embrace a small shot of nitrous, all becomes right in the world! My 10.39-128 best on Drag Week turned into 9.65-138 this year with a small shot though a plate system.
[Re: MoparBilly]
#2276743
03/26/17 09:13 PM
03/26/17 09:13 PM
Posts: 87 Michigan
Silver68RT
Now, if you are ready to embrace a small shot of nitrous, all becomes right in the world! My 10.39-128 best on Drag Week turned into 9.65-138 this year with a small shot though a plate system. Never messed with nitrous before, but I'm open to trying it. Just didn't want to try and nitrous my way into the 10's with that 360 that's in there now. I bought the R block because I wanted a solid foundation to build from, and the 48 degree version seemed like it would be a good idea if I want to run a roller cam. A friend of a friend was racing an Aspen with a 340, and he broke a bunch of blocks and ended up getting out of racing. New R block, never been used for a grand, I figured what the hell, figure out the heads later. I don't know much about the Gen III Hemi, but I'm open to checking that out too. I could always just sell the R block. I have a set of Indy 440-SR's I got a good deal on, but I was going to put those on a 440 for my '68 Charger R/T. I got the matching TTI headers for a B/E body with them. If they were EZ's with A-body headers we'd be having a whole different conversation I think.
[Re: A/MP]
#2276776
03/26/17 10:06 PM
03/26/17 10:06 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
First off this is not a forsell add. I don't really know the owner. Ok with that said has anybody heard of CPPA. Toth racing heads? I found him on face book. Looks like some nice heads he is selling? I talked to him a little bit. But didn't want to waist his time seeing I don't have the money for a set right now. Here is a screen shot I took with my phone
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: A/MP]
#2276780
03/26/17 10:10 PM
03/26/17 10:10 PM
mopar65
Oops sorry that first pic was the big block head. Here is the small block one
support our troops
[Re: moparx]
#2277050
03/27/17 11:31 AM
03/27/17 11:31 AM
mopar65
i've known bruce for quite a few years. he has been doing heads for 30+ years, and does a pretty good job in my opinion. he's a nice guy to boot, and won't try to upgrade you to something you don't need just to make extra bucks. Hey thanks for the info. Was just asking because I have never heard of him before.
support our troops
