Re: Aluminum fuel line
[Re: UCUDANT]
#2270820
03/16/17 10:11 PM
03/16/17 10:11 PM
Porter67
Ive bought a car that had that done that way and thought it was jinkie as hell and replaced it.
But id say yes.
But on my bracket car ive al. line with the... oh whats the term... its got the brass flare ring that tightens down and then an 6 male.
Compression fitting.
Long day... maybe a pic would be better.. brb.
I use a -8 compression fitting into my return line.
As nice as your red cuda is id bet you could find a compression fitting with a nipple and make it look nice and maybe a bit more "proper".
[Re: UCUDANT]
#2270841
03/16/17 10:41 PM
03/16/17 10:41 PM
RapidRobert
If only being used as a vent, or return line can aluminum fuel line be clamped to using standard rubber fuel line and hose clamps? Yes & it'll do OK as a main fuel line in that capacity also. it work hardens then cracks much easier from movement so it must be clamped securely with shorter increments inbetween the clamps.
[Re: crlush]
#2271037
03/17/17 10:24 AM
03/17/17 10:24 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Aluminum fuel line works good as long as it clamped with a good rubber lined clamp and is not rubbing on anything. I used it once and where it passed thru the frame it touched and probably vibration and hitting bumps it rubbed thru and leaked. After that i changed to braided line. This is true of any fuel line, just aluminum will probably rub thru quicker than steel or braided line.
[Re: UCUDANT]
#2271164
03/17/17 02:19 PM
03/17/17 02:19 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Summit sells tools to bend the ridges in the ends of the tube from the inside of the tube. I forget what they are called, but they look like a bolt and a nut with 3 small balls in one end.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Supercuda]
#2271178
03/17/17 02:33 PM
03/17/17 02:33 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Aluminum fuel line works good as long as it clamped with a good rubber lined clamp and is not rubbing on anything. I used it once and where it passed thru the frame it touched and probably vibration and hitting bumps it rubbed thru and leaked. After that i changed to braided line. This is true of any fuel line, just aluminum will probably rub thru quicker than steel or braided line. my concern has been with alum lines, its a lot easier to turn a small localized fire in a nice big one, if alum fuel lines are in the flames. The work harden issue with alum is reduced by optimizing one's alum alloy choice, ie 5052, which may not be easy.
[Re: Supercuda]
#2271246
03/17/17 04:54 PM
03/17/17 04:54 PM
Posts: 1,322 Michigan
crlush
Aluminum fuel line works good as long as it clamped with a good rubber lined clamp and is not rubbing on anything. I used it once and where it passed thru the frame it touched and probably vibration and hitting bumps it rubbed thru and leaked. After that i changed to braided line. This is true of any fuel line, just aluminum will probably rub thru quicker than steel or braided line. I couldn't believe how fast it rubbed thru, just lucky it rubbed thru in a spot where there was no high heat or over the exhaust.
[Re: crlush]
#2271310
03/17/17 07:01 PM
03/17/17 07:01 PM
Challenger 1
Cincinnati, Ohio
Aluminum fuel line works good as long as it clamped with a good rubber lined clamp and is not rubbing on anything. I used it once and where it passed thru the frame it touched and probably vibration and hitting bumps it rubbed thru and leaked. After that i changed to braided line. This is true of any fuel line, just aluminum will probably rub thru quicker than steel or braided line. I couldn't believe how fast it rubbed thru, just lucky it rubbed thru in a spot where there was no high heat or over the exhaust. IMO a aluminum fuel(vent/return) line on a street driven car is not good. Sure it works but it brings the quality of your car down. Because no matter how good you mount it or what kind of fittings are used it is not as good as steel. And neither is braided line. And only flare fittings should be used with aluminum line, no compression fittings. Your car is a E body, so it is easy to get pre bent lines. If your car was a unique piece then I could see the want for aluminum even though steel lines are easy to bend. Order up the line from Fine Lines or the like and have steel or even stainless steel lines and have a quality built car under ya.
[Re: Challenger 1]
#2271393
03/17/17 09:33 PM
03/17/17 09:33 PM
Posts: 8,142 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Thank you to all for the replies IMO a aluminum fuel(vent/return) line on a street driven car is not good. Sure it works but it brings the quality of your car down. Because no matter how good you mount it or what kind of fittings are used it is not as good as steel. And neither is braided line. And only flare fittings should be used with aluminum line, no compression fittings. Your car is a E body, so it is easy to get pre bent lines. If your car was a unique piece then I could see the want for aluminum even though steel lines are easy to bend. Order up the line from Fine Lines or the like and have steel or even stainless steel lines and have a quality built car under ya. I have 2 lines already and the pre bent lines sold are all designed to fit together as a pair. So making the third fit would be interesting. This is why I am asking about aluminum line to see if it is an option or not.
[Re: UCUDANT]
#2271966
03/18/17 07:59 PM
03/18/17 07:59 PM
Posts: 461 Detroit Michigan
stinger
Detroit Michigan
What about nickel copper fuel line? I read it's easy to work with and DOT approved.
[Re: UCUDANT]
#2272371
03/19/17 02:50 PM
03/19/17 02:50 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I will contact them to custom make what I want. I want a 3/8ths line to run fwd from the rear 71/72 ECS vapor liquid seperator location to the 72 vapor canister location. Basically I want the 72 factory vapor line in 3/8ths. (well unless Fi Tech says a smaller line would suffice)
EDIT I don't need 3/8ths THANKS
