Transmission ID 727? BB or SB? #2270252
03/15/17 10:35 PM
03/15/17 10:35 PM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
Hello I have a transmission that was given to me and the only thing I know is that it's from an old Mopar. The guy who gave it to me didn't know anything except it was from a Mopar. It was his roomate and he left it there we he moved out. He knew I was into Mopar and contacted me to get it out of there.
Anyway I think it's a 727 going by the trans. fluid pan shape. But here are some pics as well as the number on the LH side pan rail. It measures 35" from bell housing to tail shaft.
Is this SB? BB? Year?
Any help would be much appreciated.
Thanks beer
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270253
03/15/17 10:36 PM
03/15/17 10:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
B-RB. And don't forget to get that right side dowel pin installed back into block before install.
Re: Transmission ID 727? BB or SB? [Re: buildanother] #2270290
03/15/17 11:37 PM
03/15/17 11:37 PM
Akron, Ohio
Akron, Ohio
Originally Posted By buildanother
B-RB
So Big Block for sure correct? B block or RB block?
Thanks. beer
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270291
03/15/17 11:39 PM
03/15/17 11:39 PM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
It's out of a 76 or 77 vehicle with a 400.
Date code 11/15/1976 so it's probably a 77.
Re: Transmission ID 727? BB or SB? [Re: shocktrp] #2270301
03/15/17 11:58 PM
03/15/17 11:58 PM
Your Q has been answered but for future reference, a B/RB 727 will have (4) 1/4" dust cover mounting holes (SB has (2) 1/4" bolt holes) and facing the front of the trans a B/RB trans has a rounded face at the ~9 0'clock position (SB is kind of flat on that side). there is also a C to C dimention difference between the two top mounting bolt holes but I ain't sure what the dimentions are.
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270335
03/16/17 12:44 AM
03/16/17 12:44 AM
GEORGIA
barracuda7199 Offline
GEORGIA
Even easier way to tell sb from bb is the dowel pin holes. Small block are straight across from each other. BB the starter side is always higher than the pass. Side. With that said which ones are the dowel holes? Easy the ones that are chamfered!
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270338
03/16/17 12:44 AM
03/16/17 12:44 AM
Akron, Ohio
Akron, Ohio
Thanks to all who have replied. beer
So it looks like I have a 1977 727 for a BB.
Did Chrysler bog down the performance on their 727s as they did on their early HP motors? In other words are the mid to late 70s 727s perform the same as the early 70s 727s?
Again thanks for all of the help thus far.
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270340
03/16/17 12:48 AM
03/16/17 12:48 AM
GEORGIA
GEORGIA
Later ones have the controlled load front servo. Which you can eliminate by filling the small hole on the servo piston. Kickdown ratio will be lower on the non hipo one. It may only have a 3 clutch front drum instead of the 4 clutch one and I'm sure the governor is lower rpm. But all this can be fixed during a rebuild.
Re: Transmission ID 727? BB or SB? [Re: barracuda7199] #2270379
03/16/17 02:24 AM
03/16/17 02:24 AM
Best one yet
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270402
03/16/17 04:43 AM
03/16/17 04:43 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This is some cool stuff. I have 4 or 5 727 transmissions here and wasn't sure of the quickie methods of reference.
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270410
03/16/17 07:37 AM
03/16/17 07:37 AM
central pa
darted1 Offline
darted1  Offline
central pa
also small block bells have a top center bolt hole big blocks dont.
ED M
Re: Transmission ID 727? BB or SB? [Re: darted1] #2270426
03/16/17 10:06 AM
03/16/17 10:06 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
THE easiest way to immediately tell them apart! up
JB Rhinehart, Realist
A-Body's RULE!
Re: Transmission ID 727? BB or SB? [Re: Rhinodart] #2270485
03/16/17 12:34 PM
03/16/17 12:34 PM
GEORGIA
GEORGIA
I believe that is manual trans only guys.
Re: Transmission ID 727? BB or SB? [Re: VegasCharger] #2270570
03/16/17 03:04 PM
03/16/17 03:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IMO, the easiest way to ID BB or SB is by the converter dust cover bolt holes.
Re: Transmission ID 727? BB or SB? [Re: barracuda7199] #2270575
03/16/17 03:21 PM
03/16/17 03:21 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Transmission ID 727? BB or SB? [Re: GomangoCuda] #2270604
03/16/17 04:04 PM
03/16/17 04:04 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
scope
Re: Transmission ID 727? BB or SB? [Re: 6bblgt] #2270610
03/16/17 04:20 PM
03/16/17 04:20 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Originally Posted By 6bblgt
scope
The 3/8" inch holes at 8 and 4 o'clock are for the strut bars on a small block
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Transmission ID 727? BB or SB? [Re: Polarapete] #2270800
03/16/17 09:50 PM
03/16/17 09:50 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I just look for the curvature below the starter.
Re: Transmission ID 727? BB or SB? [Re: Hot 340] #2270845
03/16/17 10:45 PM
03/16/17 10:45 PM
Dynamite tips, take your pick!
Re: Transmission ID 727? BB or SB? [Re: RapidRobert] #2271063
03/17/17 11:17 AM
03/17/17 11:17 AM
moparx Offline
moparx  Offline
also, the starter nose locator is at 3 o'clock for the big block vs around 4:30 on the small block.
beer
