95 Cummins injector hop up?
#2270298
03/15/17 11:51 PM
03/15/17 11:51 PM
Posts: 9,841 MI, usa
dvw
MI, usa
My 95 3500 Cummins is used to tow. Total rig 19,000-20,000 lbs. It has a #10 plate, Timing advanced to 15, 4" exhaust, 3000 governor springs, boost upped to 30psi, NV4500, aftermarket 13" clutch. So it needs a head gasket and trans refresh. I'm sure the injectors could use a look. What to do? clean or upgrade. Wastegate is seized so I should get that as well. Whose head gasket? Doug
Re: (5 Cummins injector hop up?
[Re: dvw]
#2272677
03/20/17 12:13 AM
03/20/17 12:13 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
With the weight you are towing I'd keep the power where it's at. You will run into EGT issues with anymore fueling than you have now. NV4500s are weak in several areas. The stock 1 1/4 input shaft can break with a with extra power and a stout clutch. If you are going to a 13" disc, I'd upgrade to a 1 3/8 input shaft as well. 3rd gear and 5th gear are also common problem areas as well. Later style head gaskets have thicker fire rings and are better.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
