Angle of spring perches #2268858
03/13/17 08:48 PM
03/13/17 08:48 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
With the S/S springs (03-04) what angle off pinion centerline do most use when installing new perches? stock angle? Or more or less? I know ride height will have a lot to do with this, but I'm trying to keep slightly higher than normal, not a lot of room with 9x30x15s radial slicks on a ten inch rim. Thanks. Mike
Re: Angle of spring perches [Re: cudaman1969] #2269057
03/14/17 12:31 AM
03/14/17 12:31 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe you want 6* from the pinion.if you have a lot of rake in the car front to back this may help nose down 2* installed.This is just a rough guess not knowing much about the car.
Re: Angle of spring perches [Re: cudaman1969] #2269218
03/14/17 10:59 AM
03/14/17 10:59 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Until you get everything in the car, you won't know perch to centerline angle.
Bolt everything up without welding the perches, set the pinion angle with full weight ready to race car.
Tack weld the perches in place, then rip it apart to final weld.
Safest way to ensure you get the pinion angle right when you're done.
Re: Angle of spring perches [Re: dizuster] #2269511
03/14/17 06:52 PM
03/14/17 06:52 PM
fredericksburg,va
fredericksburg,va
Exactly what I was thinking, do those S/S springs need more angle then stock with the amount of rise they enable (I guess the amount of hp would afect it too)? I suppose adding or subtracting 150 pounds to jump class will change things too.
