Re: Angle of spring perches
[Re: dizuster]
#2269511
03/14/17 06:52 PM
03/14/17 06:52 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Until you get everything in the car, you won't know perch to centerline angle.
Bolt everything up without welding the perches, set the pinion angle with full weight ready to race car.
Tack weld the perches in place, then rip it apart to final weld.
Safest way to ensure you get the pinion angle right when you're done. Exactly what I was thinking, do those S/S springs need more angle then stock with the amount of rise they enable (I guess the amount of hp would afect it too)? I suppose adding or subtracting 150 pounds to jump class will change things too.
