Re: 1964 newport issue [Re: Supercuda] #2197027
11/15/16 10:52 PM
11/15/16 10:52 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By Supercuda
No, there is a N pushbutton as well, just that when you put the park lever into Park is also pushs in the N pushbutton, they are mechanically interlocked. P also engages N, but N does not engage P, if that makes sense.
Yep, it does.
That sounds real familiar.
SO,
the neutral button would have activated the safety switch for the starter, and it's in the valve body like later models?
Park also applied it?
O.P. must check the switch at the trans to identify the trouble?
I'm following this now.
A friend just sold a 62 New Port this past summer and he mentioned the park being a brake on the rear of the trans. Don't recall how it applied though.
It was about '76 when I had my '64 New Yorker.
Neat old car. up
Great interior. grin
Lots of "watch this" handles. whistling
I have mechanical Aptitude.
I can screw up anything.
Re: 1964 newport issue [Re: mb69] #2268670
03/13/17 03:43 PM
03/13/17 03:43 PM
Pennsylvania
mb69 Offline OP
mb69  Offline OP
Pennsylvania
Hey guys sorry I didn't get back sooner, I replaced the neutral safety switch and it started right up. Thanks for the help.
Re: 1964 newport issue [Re: bboogieart] #2268733
03/13/17 05:15 PM
03/13/17 05:15 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Yep, it does.
SO,
Neat old car. up
62 was the first year for the aluminum case and the last year for the tailshaft parking brake. No "Park" in the trans.
It's a one year only trans and the hot setup to put a "modern" 440 and 727 in an extended crank 413 with cast iron Torqueflite car and keep the pushbuttons.
Parking brake was pedal applied.
Kevin
Re: 1964 newport issue [Re: Twostick] #2268772
03/13/17 06:47 PM
03/13/17 06:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In '62 only the full-sized cars (Chrysler, Dodge 880) had the tail-mounted parking brake; the B-bodies got the internal Park mechanism activated by a separate cable.
