Rebuilding an OLD engine,1954 red ram 270 V8 #2268513
03/13/17 11:29 AM
03/13/17 11:29 AM
Finally a HUSKER again
Moparnut426 Offline OP
I go this ol 54 wide block V8 tore down this weekend, Its in amazing shape except for the cam. I can no fond a cam anywhere to save my AZZ. I googled 270 red ram Camshaft, Ive tried looking up old 54 DODGE specs, I cant find anything. The cam is too far gone to be saved by a re grind, and it the only thing holding me up for my customer.
Im usually pretty good with the ol google machine, but this ones got me stumped.
ANY HELP is appreciated
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268514
03/13/17 11:33 AM
03/13/17 11:33 AM
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268519
03/13/17 11:49 AM
03/13/17 11:49 AM
HOLY CRAPOLA
http://www.ebay.com/itm/Dodge-270-Poly-Deluxe-engine-kit-1955-56-Plymouth-pistons-rings-gaskets-chain-/170896459759?hash=item27ca3907ef:g:YrMAAOxyFPNSKJ6Q&vxp=mtr
I do believe this it it!
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268520
03/13/17 11:50 AM
03/13/17 11:50 AM
jersey
Spaceman Spiff Offline
jersey
Hot heads maybe?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268531
03/13/17 12:03 PM
03/13/17 12:03 PM
no cam in this kit.
I called this number and there are NO CAMS AVAILABLE FOR THIS ENGINE!!!
Inly a rebuilt cam and a core required before I can buy a rebuilt cam.
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268534
03/13/17 12:10 PM
03/13/17 12:10 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
If it's a Poly, wouldn't Gary Palpovich be able to help you? I was told he is the guy for poly parts.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268536
03/13/17 12:12 PM
03/13/17 12:12 PM
Do you have his Info?
And thank you
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268545
03/13/17 12:25 PM
03/13/17 12:25 PM
Spaceman, I don't know if the cam from a Poly to a HEMI are the same this is a Poly head 270
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268550
03/13/17 12:34 PM
03/13/17 12:34 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
I found this on the web, I believe this is the email I used to contact him years ago.
glpavlovich@cox.net
1966 Fury II 4 door
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268552
03/13/17 12:37 PM
03/13/17 12:37 PM
I
Interceptor72 Offline
I
There are no cams or cores available for this engine. Unless you can find a usable core, you are SOL.
I believe the cores (i.e., they will physically interchange) for all the Dodge hemis and polys should be the same, though. But the valve timing is very different due to different angles of the lifters in the block.
Whether there is enough meat there to regrind a hemi into a poly (or vise versa), I don't know.
I have a reground cam for what I BELIEVE is a Dodge hemi, but might be a poly. Bought on ebay a long time ago. That's why I can't be 100% sure what it really is. Definitely for the Dodge block, though.
Since it's been reground once already, I cannot be sure if there is enough left to do another regrind or not.
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268557
03/13/17 12:42 PM
03/13/17 12:42 PM
OK thanks guys Ill keep checking, This truck was bought new by my customers grandpa, and its his dads now. He wants it done for Fathers day, but I doubt that will happen now...
Kasey
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268562
03/13/17 12:49 PM
03/13/17 12:49 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
If you get hard up, shoot me a PM. I can pull the cam out of my old poly and send it to you if need be. I'm sure theres some other folks on here with polys in the backyard that you can get a cam from also.
1966 Fury II 4 door
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268565
03/13/17 12:56 PM
03/13/17 12:56 PM
USA
Grizzly69 Offline
Grizzly69  Offline
USA
egge.com
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268568
03/13/17 01:05 PM
03/13/17 01:05 PM
King Tuna!
Thank you!
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268574
03/13/17 01:16 PM
03/13/17 01:16 PM
warren, mich.
dwayne welder Offline
warren, mich.
Racer Brown Camshafts on the east coast can regrind the cam. He has Masters for the old engines. Back in October he regrind a 325 Cid. 2-4bbl hemi cam for my customer. Good Luck
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268584
03/13/17 01:31 PM
03/13/17 01:31 PM
Well I spoke with my Customer, I know of a truck, a 79 2x4 dodge with a 360. He is buying that, and Ill build brackets, and stick that in it for him. Will be happier with that anyway.
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268651
03/13/17 03:16 PM
03/13/17 03:16 PM
dogdays Offline
dogdays  Offline
Man, I love those tiny Dodge Hemis! They're just the right size to slip between the rails of a '30s car. If I was a little closer I'd make him an offer on the engine. It'd move a 2000lb hot rod around "might smart".
Whatever you do, don't scrap it or set it out in the weather.
This guy does camshafts for old engines:
(If he's still alive and grinding)
Chris Neilson Cams (801) 451- 7745 Box 416 Farmington, UT 84025
New reproduction cams for early Mopar Hemi / Poly, & other
engine parts, bearings, pistons, etc.
Gary Pavlovich is interested in the Plymouth Poly, mostly.
Chrysler, Desoto and Dodge each had their own design Hemi. Each family had a different bore spacing. The Plymouth Poly doesn't share bore spacing with any of them. So four different engine designs, no interchange of most any part.
IIRC polys and Hemis from the same engine family shared intake manifolds.
R.
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268723
03/13/17 05:03 PM
03/13/17 05:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I wouldn't use "wide block" to describe the engine, that's generally reserved for the Plymouth poly (pre "LA" wedge) "A" engine.
The engine is quite wide across the exhausts and very heavy, only the bore pitch is small and unique at 4-3/16".
The 270 can only use low-deck Dodge 241, 259 or 270 cams due to the lifter angle difference, but hemi and poly had the same angle. All DeSoto poly engines are actually Dodge.
IIRC you also have to match the cam nose drive type, 1951-54? or 1955-58.
Visually, the Chrysler 301, 331, 354 poly looks very much like the Red Ram except for 3-bolt valve covers (and considerably larger).
Boffin Emeritus
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268737
03/13/17 05:20 PM
03/13/17 05:20 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
All the early first generation hemis up to 1956 were plagued with soft cams.Even if you found a usable core the regrind and process of hardening would be costly and any performance from those early engine is minimal.If your going to consider any early hemi look to the 354 and 392 but remember these are enormously heavy engines.
Re: Rebuilding an OLD engine,1954 red ram 270 V8 [Re: Moparnut426] #2268738
03/13/17 05:24 PM
03/13/17 05:24 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Chrysler Power has been running a series on building the old poly head engines. Might be worth checking it out.
