92 5.2 Magnum Questions, Changing Out A 318 La #226847
02/16/09 04:51 PM
02/16/09 04:51 PM
South Dakota, US
2
27whippet Offline OP
South Dakota, US
I have a 5.2 from a 92 Dodge van and am wondering if an oil pan from a 76 Dodge 318 will work on the 5.2 magnum? Also, would it be best to use the flexplate that's already on the magnum engine or can I use the flexplate from the LA 318? I want to be able to bolt a 74 904 up to the engine. I also have been looking at changing the cam but don't know what to go with? We plan on running the engine in a 34 Dodge with a 904 trans. Rear gear ratio is 3:00, tires are 235/75/15. We would like something with a nice lope and decent idle. Car will be used as a driver in and out of town. We have read some about cam selections but don't want to go with a cam that requires cutting the guides. We would like to run a mechanical fuel pump as well. We are switching the engine over to carburated with dual exhaust. We have a Carter AVS 625 CFM carb and want to double check if this cfm is a good one?
Thanks for the advice.
Erick
Re: 92 5.2 Magnum Questions, Changing Out A 318 La [Re: 27whippet] #226848
02/16/09 05:02 PM
02/16/09 05:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The flex plate can be used and is stronger than a regular flex plate but only if you use a newer style mini starter.
The pan won't fit, an LA 360 pan will fit or any magnum V8 pan.
Re: 92 5.2 Magnum Questions, Changing Out A 318 La [Re: 27whippet] #226849
02/16/09 05:43 PM
02/16/09 05:43 PM
scratchnfotraction Offline
check out hughesengines.com
look at the 318 "whiplash" cams
the 318 muscle car cam HMC132AL-9
idles like a funny car smooths out 1600-1800 rpms
great cruzing cam,ask for it in a long nose roller cam...they are not advertising the roller whiplash yet..
I am going to be running one very soon over the lunati voodoo 60710 roller cam I have now
should sound nasty in a magnum but tame enuff to cruz a 34 around
want more try the 340/360 whiplash
the sales ad got me with idles like a funny car smooths out 1600-1800 rpms...thats just what I wanted a poser cam for the cruz in car shows
do you need a rear sump pan for a 34?
either way a 360 pan works..car or truck pan
just need to know what sump will fit for you
Re: 92 5.2 Magnum Questions, Changing Out A 318 La [Re: HotRodDave] #226850
02/16/09 06:51 PM
02/16/09 06:51 PM
Andrewh Offline
Andrewh  Offline
I think that the magnum flex plate can be made to work with the 904. There is one hole that doesn't quite line up and you can wallow it out so it bolts up.
You have to change the front of the motor to the la style to put in a mechanical pump. There is an adaptor you can buy to bolt up to the front of the cam so you have an ecentric to run the fuel pump. But I think you loose all the serpentine belt stuff that way.
Exhaust from a truck about the same year should work fine. You could also see how the van exhaust lines up.
Re: 92 5.2 Magnum Questions, Changing Out A 318 La [Re: 27whippet] #226851
02/17/09 09:24 AM
02/17/09 09:24 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
get some GM 3100/3400 V6 springs and retainers, for a cam, I'd look at a comp XR258HR. I'd get it custom ground on a long snout core so you can run the mechanical fuel pump (or just get the $18 snout extension from mancini).
as others have said, to run a mechanical pump, you'll need to ditch the serpentine drive and run an LA timing cover/accessory drive.
oil pan is common with all 360's.
2017 Grand Cherokee Overland
