Switching from a 4.10 to 3.55 #2267542
03/11/17 05:57 PM
03/11/17 05:57 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Hey guys - Since my racing opportunities are few and far between, I decided to pull the 4.10 out and just purchased a new 3.55 3rd member from Dr Diff. I still want to race every now and then and prepared for the 60fts to suffer. For those of you who have made a similar change in favor of better street manners, what was your real world drop off in ET? Havnt raced it with the new engine, so I wont know the difference...I actually gave some thought to 3.23's. I think I'm getting old.
2 kids and a dog
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267549
03/11/17 06:10 PM
03/11/17 06:10 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
My 67 dodge coronet went 11:40 with a 4.10 28" tall radials, went to the 3.55 went out with the same tires, ran a best of 11:58. The 60 ft dropped almost a tenth. But for street driving it was a god send.. I did later switch to a 26 in tire and got some of it back. IIRC it went 11:47. I would have to dig out my log book to be sure though. Good luck.. Have fun
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267554
03/11/17 06:17 PM
03/11/17 06:17 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
"But for street driving it was a god send." This is what im hoping for!
Thanks for sharing your ets. I figured there would be a drop off. Not horrible
2 kids and a dog
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267694
03/11/17 10:37 PM
03/11/17 10:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Tony I run a 3.23 in my Duster, it's the steepest gear I can handle on the highway. I run a 28" radial street tire on the street and I'm gonna try a 26" slick if I ever get it to a track. With a stroker motor and fairly loose converter the car feels like it has a 4.10 in it.
There's some good info here.....
https://board.moparts.org/ubbthreads/ubbt...-3-55-gear.html
Re: Switching from a 4.10 to 3.55 [Re: ProSport] #2267794
03/12/17 12:54 AM
03/12/17 12:54 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The 505 in my '63 loves the 3.54 gear!
No way I'd run a deeper gear...
'63 Dodge 330
11.19 @ 121 mph
Re: Switching from a 4.10 to 3.55 [Re: GY3] #2267810
03/12/17 01:16 AM
03/12/17 01:16 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Try a low first gear in the tranny ?
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267812
03/12/17 01:19 AM
03/12/17 01:19 AM
IL
furious70 Offline
furious70  Offline
IL
I suppose it depends on how hot the combo is. Years ago there was a thread about 4.10 to 3.23's I thought for 'warm' 440's, and I even thought GY3 was one of the people who replied and said not much difference in ET. Theory being a 'warm' cam and still stock(ish) heads on a 440 don't change the torque curve enough that the 4.10's were ever really needed.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Switching from a 4.10 to 3.55 [Re: furious70] #2267819
03/12/17 01:33 AM
03/12/17 01:33 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Good memory!
I did test a very mild smallblock powered '71 Cuda back in the late 90's going from 3.23's to 4.56's. Car e.t.'d virtually the same.
I've never done it with a 440, though, as I never felt a torquey street motor needed anything deeper than 3.55's.
'63 Dodge 330
11.19 @ 121 mph
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267928
03/12/17 11:53 AM
03/12/17 11:53 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I agree that there will definitely be some combos that need more gear than others. My engine is a 520 with good torque all the way around. Cam is a pretty mild 252@.050 hydraulic roller, and I have a 9 1/2" converter and 28" tire. It is a heavy car though at just over 4000 w me in it.
2 kids and a dog
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267933
03/12/17 12:03 PM
03/12/17 12:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
FWIW, back in the 12s (ETs, not years), the difference I saw between 3.55 and 4.10 was .2 in ET with no change in MPH.
Re: Switching from a 4.10 to 3.55 [Re: GY3] #2267935
03/12/17 12:04 PM
03/12/17 12:04 PM
IL
furious70 Offline
furious70  Offline
IL
Good memory!
Based on the details, the memory was actually incredibly foggy! Seems like a 520 should have plenty of pull to not feel it and/or move to 26" tires for the track like others mention.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2267997
03/12/17 01:49 PM
03/12/17 01:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you have a non race suspension to begin with and running a street tire, the tire is your limiting factor, so I would guess you would give up .1 to .2. If you have a street suspension and you are going to throw on some sticky tires, probably .2 to .3. That's my guess.
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2268148
03/12/17 05:53 PM
03/12/17 05:53 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I'm thinking along similar lines with my 512" Duster; the 3.91s are pretty busy on the highway, and I need to run 65-70 for almost an hour to the nearest track. All the while, I'm thinking about how long the stroke is and a 505" Challenger I know that runs 11.50s with 3.23s and the same 28" diameter street tire. That's good enough for this car, as I already have a high-strung 10-sec SB car...
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2268167
03/12/17 06:29 PM
03/12/17 06:29 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Hopefully in a couple months I can report back with some results with my 3.23's in my Duster. I didn't care for the 3.55's on the highway but the 3.23's are livable. I'm around 2600 on the highway with a 27.5" tall tire.
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2268540
03/13/17 12:18 PM
03/13/17 12:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
At over 4000 pounds the 3.55's will probably be the best choice for you Tony.
Re: Switching from a 4.10 to 3.55 [Re: ProSport] #2269323
03/14/17 01:41 PM
03/14/17 01:41 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
That's what I'm hoping for, Bob. Thanks
2 kids and a dog
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2269826
03/15/17 06:33 AM
03/15/17 06:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am curious to see what it does. I have heard of guys with 500 strokers dropping from 4.10's to like 3.55's and going just as fast. I honestly think my 63 may go faster if I drop a little gear. I think I am above my peak torque at the traps and have been thinking of dropping my 4.30's to about 3.91's. But I do run a 30" tall tire. You may not loose much if any Tony. Keep us posted on how it goes because I want to know. Ron
Re: Switching from a 4.10 to 3.55 [Re: TonyS451] #2269881
03/15/17 11:25 AM
03/15/17 11:25 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I run a 3.55 now, but I am looking to swap in a 4.10 to be able to run on a 11.50 index. From what I recall it was 0.1-0.2 quicker with the 4.10. 493" with 9.5" converter, 28" tire
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Switching from a 4.10 to 3.55 [Re: OUTLAWD] #2270516
03/16/17 01:34 PM
03/16/17 01:34 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
What axle? I've got a 8.75" with a 489 case, SG 4.10 that I'd like to go back to 3.55. You open to the idea of trading?
Re: Switching from a 4.10 to 3.55 [Re: MarkZ] #2270538
03/16/17 02:08 PM
03/16/17 02:08 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Sorry Mark, not looking to trade at the moment. I have a 4.10 spool pumpkin ready to go with aftermarket axles. I'm sure I'll get tired of the 4.10's and go back to the 3.55's anyway. I drive on the street too much
