Which fuel pump for my Hemi Ram......
#2267177
03/11/17 01:35 AM
03/11/17 01:35 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I looked on Rockauto.com and they have several different fuel pumps for my truck. They list pumps for different gallon tanks (19,26,34 and 35 gallon). They also list pumps for, engine vin 2,engine vin D and engine vin 2 code EZB. The problem is I do not know which one I need. It is a 2008 4 door Dodge Ram 5.7 Hemi Big Horn. How do I find out which one I need.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Which fuel pump for my Hemi Ram......
[Re: D-50]
#2267321
03/11/17 12:22 PM
03/11/17 12:22 PM
D-50
North, Alabama
Can anybody help me figure out the fuel pump I need in the above post.. Thanks...
[Re: D-50]
#2267396
03/11/17 02:05 PM
03/11/17 02:05 PM
Posts: 684 Maine
jerseybud
Maine
Most trucks you can crawl under the truck and look at the plastic casting on the fuel tank bottom- should say gallons.
Vin number is on the drivers side dash visible thru windshield, or drivers door/door jam placard. I like delphi pumps or carter, if OEM , personally. Better yet is a mopar oem
[Re: mopars4ever]
#2271480
03/17/17 11:58 PM
03/17/17 11:58 PM
Posts: 858 Southeast Pa.
SALEM1912
Southeast Pa.
Give me the last 9 of the vin I could tell you what size tank.Or try the vin decoder mopar4ever posted it works good.
