Dead short? #2267038
03/10/17 09:13 PM
03/10/17 09:13 PM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Hey guys, here's a head scratcher for you. A friend of mine bought a car and I was trying to help him get it running today.. He heard it run before he bought it, but it's been sitting for a year since. We put a brand new battery in it, it turned over very slow then clicked like battery was dead.. Put a known good battery out of his driver in it, same result.. We figured maybe starter was bad from sitting, replaced it.. It turned over a little faster but quickly drew the battery down.. I ran a jumper cable straight from the battery to the starter terminals still same result. Also the car has B&M shifter, it was resting against the bellhousing.. It got hot and started to melt the insulation on it, we traced the whole cable from the shifter to the transmission lever, it touches no wiring anywhere.. I've never seen such a thing.. Any ideas?
Re: Dead short? [Re: EV2RUNNER] #2267039
03/10/17 09:19 PM
03/10/17 09:19 PM
Mass
charge70 Offline
charge70  Offline
Mass
Sounds like a bad ground.The engine is trying to ground itself thru the shifter cable,thats why its melted.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Dead short? [Re: EV2RUNNER] #2267047
03/10/17 09:29 PM
03/10/17 09:29 PM
St.Clairsville Ohio
St.Clairsville Ohio
That's what I was wondering too, it's got a ground on the head, maybe the cable is bad. Thanks
Re: Dead short? [Re: EV2RUNNER] #2267050
03/10/17 09:39 PM
03/10/17 09:39 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A ground on the head is useless, as to properly ground out it must go through isolated rubber motor mounts..
Put a direct ground strap between the block and back to the firewall or frame.
Now try it...
Just my $0.02... wink
Re: Dead short? [Re: EV2RUNNER] #2267052
03/10/17 09:45 PM
03/10/17 09:45 PM
St.Clairsville Ohio
St.Clairsville Ohio
The head is bolted straight to the block?
Re: Dead short? [Re: charge70] #2267058
03/10/17 10:00 PM
03/10/17 10:00 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
This/\
I did a trans for a guy with a Vette. Worked fine until he got it out of winter storage. Car was sluggish turning over and when it did start it had no gears. Pulled it apart and the seals had melted. It was trying to ground through the trans. Cleaned up the chassis grounds and it was good to go.
Re: Dead short? [Re: EV2RUNNER] #2267123
03/11/17 12:18 AM
03/11/17 12:18 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Yeah but...
The head and block float above ground..
They are isolated from being a solid, reliable ground as the 12V must try and flow through rubber insulated motor mounts to the car frame. A DIRECT grounding strap from the engine to the frame and/or firewall assures a solid ground connection.
Keep in mind, the starter draws > 100amps and without a solid ground for the 12V- other problems can/will happen..
Just my $0.02.... wink
Re: Dead short? [Re: Sinitro] #2267142
03/11/17 12:48 AM
03/11/17 12:48 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes check for that good ground from batt term to solid part of engine, manifold, head, block, whatever. The GM cars use to get corroded neg batt ends and ground thru shifter cable like mentioned above.
Re: Dead short? [Re: Sinitro] #2267160
03/11/17 01:19 AM
03/11/17 01:19 AM
St.Clairsville Ohio
St.Clairsville Ohio
Well it's grounded from the negative terminal straight to the cylinder head with 4 gauge battery cable. Maybe I'm wrong but why would it still have to be grounded to the frame? Im thinking it may be corroded where it is bolted on the head or the cable is broken inside the sheathing.
Re: Dead short? [Re: EV2RUNNER] #2267178
03/11/17 01:44 AM
03/11/17 01:44 AM
chicagoland,usa
chicagoland,usa
There always needs to be a ground from batt to body, but the larger gauge wire always goes to engine from the batt to carry the great current to the starter to crank the thing.
Re: Dead short? [Re: EV2RUNNER] #2267201
03/11/17 02:47 AM
03/11/17 02:47 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Several reasons..
1. When the car was built it had at least 2 wire links grounding the engine to the frame
2. When the starter is activated a significant current pull (>100 amps) is made from the battery so if there are missing and/or poor grounds the voltage will travel in strange ways
3. A unitized ground system is required for a proper running ignition/electronic plus minimizing electrical noise interference
4. Even more important in todays sophisticated computer car systems
Many users fail to understand how to wire/maintain a reliable electrical system, as long as it works its OK...
Re: Dead short? [Re: EV2RUNNER] #2267244
03/11/17 07:46 AM
03/11/17 07:46 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Using a meter check engine, chassis, body, starter housing, etc. to battery negative for differing resistance levels. Might too even do so with a helper while cranking engine.
Re: Dead short? [Re: EV2RUNNER] #2267270
03/11/17 10:31 AM
03/11/17 10:31 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Funny every early Mopar Ive had since the 60s had the batt ground to the motor.The small ground on the back to firewall is to ground for the body not the starter.Sounds like either bad cables,bad starter,or motor locking up.The starter and ground are all grounded thru the block.I had a GM once new motor.Tried to start and smoke came up.Seems my buddy had the small ground wire attached but the large one that bolted to the alt bracket wasnt.Attached it and all was goog.Just because cables look good they can be corroded inside.Rocky
Chrysler Firepower
Re: Dead short? [Re: EV2RUNNER] #2267279
03/11/17 10:51 AM
03/11/17 10:51 AM
Mass
charge70 Offline
charge70  Offline
Mass
Try using a set of jumper cables as temporary gounds.At one end put both to the neg term on the battery and the other end put one on the block and the other on the chassis and see if that fixes the problem
Re: Dead short? [Re: Sinitro] #2267293
03/11/17 11:12 AM
03/11/17 11:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yeah but...
Don't know what your doing, do ya?
What are you grounding the engine and body to?
The battery
a ground cable from the head to the battery is perfectly acceptable for grounding the engine including the starter. After all the factory grounded million of car that way. The ground between the block and body to to ground the BODY to the engine.
Don't be the exception.
Re: Dead short? [Re: EV2RUNNER] #2267305
03/11/17 11:37 AM
03/11/17 11:37 AM
Well it's grounded from the negative terminal straight to the cylinder head with 4 gauge battery cable. Im thinking it may be corroded where it is bolted on the head or the cable is broken inside the sheathing.
Correct, you have a known good battery/starter so it has to be in the large cables. Clean each terminal/connection (power and ground paths) & you should be good. also once I had a cheap made overseas cable that had a layer of green corrosion inbetween the strands and the crimped end terminal, took a bit to figure that one out. Oil/grease inbetween the starter/thin plat/block could interrupt that flow but is rare cuz there is alot of metal surface contact area with the starter wide flange down there. iirc you jumped it straight to the battery & still bad so start with the ground paths. EDIT & was the neg jumper cable clamped to the starter case?
Re: Dead short? [Re: EV2RUNNER] #2267338
03/11/17 12:48 PM
03/11/17 12:48 PM
Minn
SportF Offline
SportF  Offline
Minn
The starter draw can be in excess of 250 amps.
Re: Dead short? [Re: SportF] #2267377
03/11/17 01:49 PM
03/11/17 01:49 PM
& starters are weird electric motors in that the slower they turn the more current they need/draw so a poor connection will slow it down which wants more current (which ain't available) which slows it down even more which draws even more current & this happens in a matter of a second or two till you hear the machine gun clatter of the pull in/hold in solenoid circuits activating back & forth.
Re: Dead short? [Re: Supercuda] #2267477
03/11/17 04:10 PM
03/11/17 04:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Yeah but...
The battery
The battery's negative terminal should have a solid, clean ground to the engine block, frame and body. If the Mopar is 50 years old, running a 35 amp alternator with stock accesories one may get by with less... rolleyes
However...
Later cars and/or including Mopars which have been updated to include ECUs, electric fuel pumps, electric fans, subwoofer system REQUIRE a solid high integrity ground system is pertinent for reliable operation.
Regarding the question.. "Don't know what your doing, do ya?"
I would respond to this by saying.. "Yes we do..."
Here is short summary of my background..
* 35 years of experience of designing auto electrical systems
* 40% of the later cars built since 1995 utilize our designed electrical
systems/components
* Designer/builder of multiple high-profile demo cars for CES & SEMA
* Written multiple major publication articles on electrical systems/wiring
* Holder of multiple patents
If U require more info/knowledge on how to wire auto electrical systems and the importance of proper grounding..
PM me and I will forward more details on the subject.
Just my $0.02.. wink
Re: Dead short? [Re: EV2RUNNER] #2268405
03/13/17 12:37 AM
03/13/17 12:37 AM
St.Clairsville Ohio
St.Clairsville Ohio
Ok here's what the issue was guys, the large ground wire that went from the battery terminal to the head was broken inside the insulation on the battery terminal side. We replaced the cable and she turned right over. Thanks for the replies
