Edelbrock Dual Quads
#2266652
03/10/17 09:41 AM
03/10/17 09:41 AM
Posts: 216 united kingdom
Simonic
united kingdom
Hello. Is anybody out there running the Eelbrock dual quad set up on a 440? I'd be interested to know how it performs and any tuning/running issues you may have. Thank You
Keeping the Bee Buzzin'
Re: Edelbrock Dual Quads
[Re: max_maniac]
#2266725
03/10/17 12:57 PM
03/10/17 12:57 PM
Simonic
united kingdom
Thank You My car is exclusively a street car.71 Superbee with a 4 speed. It's lumpy at tickover and the car is jerky when decelerating at lowish revs.
[Re: SportF]
#2266750
03/10/17 01:28 PM
03/10/17 01:28 PM
RapidRobert
I knew a guy who ran dual quad thermoquads using the adapter plates on an offy intake on a street 440 & it was an excellent setup. the carbs were identical numbers & were gone thru meticulously.
[Re: Simonic]
#2267265
03/11/17 10:11 AM
03/11/17 10:11 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
Thank You My car is exclusively a street car.71 Superbee with a 4 speed. It's lumpy at tickover and the car is jerky when decelerating at lowish revs. You may need to clarify for us Yanks. Does "lumpy at tickover" mean runs rough after cold start up? "Jerky when decelerating at lowish revs", This one doesn't sound like a carb tuning problem. Maybe you need to shift to a lower gear? Push in the clutch?
[Re: TooMany62s]
#2267392
03/11/17 02:01 PM
03/11/17 02:01 PM
Posts: 6,567 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Thank You My car is exclusively a street car.71 Superbee with a 4 speed. It's lumpy at tickover and the car is jerky when decelerating at lowish revs. You may need to clarify for us Yanks. Does "lumpy at tickover" mean runs rough after cold start up? "Jerky when decelerating at lowish revs", This one doesn't sound like a carb tuning problem. Maybe you need to shift to a lower gear? Push in the clutch? Yes, some details will help. First are you asking about just the Edelbrock carbs themselves or the CH28 2x4 intake and carbs as a package? The manifold, and there are several different ones, can have more to do with how 2 fours behave than the carbs themselves. Stock cam? If not we need some cam specs to tell if "lumpy at tickover" has more to do with cam than carb. Rear axle ratio? If it has a big cam, dual carbs and 2.76 rear gears it's not going to behave very well chugging around town in 3rd gear. Kevin
[Re: Simonic]
#2267410
03/11/17 02:25 PM
03/11/17 02:25 PM
Posts: 31,053 Oregon
AndyF
Hello. Is anybody out there running the Eelbrock dual quad set up on a 440? I'd be interested to know how it performs and any tuning/running issues you may have. Thank You Check the tech archives on any BB Mopar configuration question. Odds are that over the last 20 years I've tested it and written up the results: http://www.hotrod.com/articles/1007phr-big-block-mopar-engines/
[Re: Twostick]
#2267500
03/11/17 04:47 PM
03/11/17 04:47 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
This. Just not too sure the responses so far are in line with what the question is. I thought he was asking about the Edelbrock CH28 "set up"
[Re: BSB67]
#2267957
03/12/17 12:46 PM
03/12/17 12:46 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
This. Just not too sure the responses so far are in line with what the question is. I thought he was asking about the Edelbrock CH28 "set up" From the original post all he is asking about is the carbs on a 440. No where does he state anything about the intake unless the post has been modified?
[Re: max_maniac]
#2268030
03/12/17 02:56 PM
03/12/17 02:56 PM
Twostick
Still wishing...
Still wishing...
This. Just not too sure the responses so far are in line with what the question is. I thought he was asking about the Edelbrock CH28 "set up" From the original post all he is asking about is the carbs on a 440. No where does he state anything about the intake unless the post has been modified? Is anybody out there running the Eelbrock dual quad set up on a 440? "Set up" implies to me a complete system. He asked about Edelbrock specifically so the kit Summit sells with the CH28 was the first thing that came to mind. 2 Edelbrock carbs on an OEM inline 413 intake are going to behave/tune differently than on a tunnel ram or MW type crossram. Kevin
[Re: max_maniac]
#2268136
03/12/17 05:37 PM
03/12/17 05:37 PM
BSB67
Prospect, PA
Maybe. I simply don't know what he is asking. If you show me the word "carbs" then I'll show you "intake". And the sentence is written in the singular " the...set up" and not plural which would have been: "...Edelbrock dual quad s..." But then again, I sometime don't understand what I write. Finally, without knowing both the intake, and the specific Edelbrock carbs he is inquiring about, I'm not sure how any response would be very meaningful.
[Re: TooMany62s]
#2270136
03/15/17 07:10 PM
03/15/17 07:10 PM
Simonic
united kingdom
My apologies 'lumpy at tickover' means when the engine is t running temp the ticover is not clean,it's up and down as if it's got a big cam.Idle speed is about 700
Jerky when decelerating,anything less than 2 grand
[Re: AndyF]
#2270137
03/15/17 07:10 PM
03/15/17 07:10 PM
Simonic
united kingdom
Please excuse my typo...............
