Front tire size B body #226618
02/16/09 12:33 PM
02/16/09 12:33 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
what's the biggest tire you have on your 66-70 b-body...Looking at a 255/50/17 on a 17X7 with 4.25 backspaced rim.. It's 27" in diameter and section width of 10.03"..Think it will fit?
Re: Front tire size B body [Re: kbcuda] #226619
02/17/09 10:08 AM
02/17/09 10:08 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Anyone?
Re: Front tire size B body [Re: kbcuda] #226620
02/17/09 10:56 AM
02/17/09 10:56 AM
Texas
RaiderLefty Offline
RaiderLefty  Offline
Texas
I just put a 255/45/18 on the front of my '68 RR and it fits with no problem.
Backspacing is 4.75" and I could have probably gone to 4.5" as there's a minor issue with rubbing at full lock.
I was told a 275 would fit with no problem but decided to go with the 255s instead.
Re: Front tire size B body [Re: RaiderLefty] #226621
02/17/09 07:54 PM
02/17/09 07:54 PM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
i have 255/60/15s on all four. i have my ride height set at 25 1/2inch from ground to wheel well. 4.5 in backspace. this puts the tire just inside the wheel well. if i raised my ride height to expose the tire i can put 275/60s. if not they rub when wheel is turned.
Re: Front tire size B body [Re: lokalik] #226622
02/17/09 08:17 PM
02/17/09 08:17 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I just installed 225/60/15 on 15 X 7 wheels with 4" backspacing.. Perfect..
Back wheels are 15 X 8 with 5 1/4" backspace with 245/60/15...
67 coronet
