A-arm question and torsion bar question #226593
02/16/09 12:17 PM
02/16/09 12:17 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I have a 68 dodge charger that needs A-arms as the old ones seem to be to heavily rusted to reuse. Will all 66-70 A-arms off a B-body work. And where are some good places to buy a used set.
Also need a good place that sells high quality torsion bars at a bargin price.
Thanks in advance.
Re: A-arm question and torsion bar question [Re: rapom] #226594
02/16/09 12:23 PM
02/16/09 12:23 PM
NY NY
3
340duster340 Offline
NY NY
if you are ok with aftermarket parts, www.firmfeel.com makes a great set of tubular upper control arms, loaded with busings, they are a better value than rebuilding the original pieces IMO
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: A-arm question and torsion bar question [Re: 340duster340] #226595
02/16/09 05:14 PM
02/16/09 05:14 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
$350 seems very expensive. Espo quoted me $50 for the upper ball joints and the a-arm bushings for both a-arms.
Re: A-arm question and torsion bar question [Re: rapom] #226596
02/16/09 05:25 PM
02/16/09 05:25 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
the 350 is for the arms, ball joint and bushings.
Re: A-arm question and torsion bar question [Re: skajm] #226597
02/16/09 06:42 PM
02/16/09 06:42 PM
FT. Worth TX
P
PASTLITE Offline
PASTLITE  Offline
P
FT. Worth TX
Upper control arms you need can come from
62-64 Ply.,Dod., Except Valiant,Lancer.880.Dart
65-72 Belevedere,Coronet,Satellite
66-72 Charger
73-74 Barracuda,Challenger
Re: A-arm question and torsion bar question [Re: rapom] #226598
02/16/09 08:17 PM
02/16/09 08:17 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would give these guys a call -
www.wildcatmopars.com
Re: A-arm question and torsion bar question [Re: skajm] #226599
02/16/09 08:24 PM
02/16/09 08:24 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I know, $299 is the price for both a-arms without bushings and ball joints. that is still expensive, unless used a-arms are over $100. Then I might think about buying the tubular ones.
I will check out wildcat's prices.
Re: A-arm question and torsion bar question [Re: rapom] #226600
02/16/09 08:33 PM
02/16/09 08:33 PM
NY NY
3
NY NY
exactly you still need to find a set of used control arms, plus don't forget get once you get them your going to have to clean and paint them + install bushings
and after all that you still have 30 year old flimsy stock stamped steel control arms.
Re: A-arm question and torsion bar question [Re: 340duster340] #226601
02/16/09 09:33 PM
02/16/09 09:33 PM
IN
ahy Offline
ahy  Offline
IN
I've got a set of upper control arms from a '70 Challenger. I'm not sure they would fit, if you're interested, PM me. Also, a set of OE torsion bars. Parts are from a California 318 car and in good shape.
If you're looking for new T bars, try Firm Feel or Mancini.
