Re: 94 dakota v6 to 5.9
[Re: kenworth_goose]
#2262724
03/03/17 04:18 PM
03/03/17 04:18 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would just grab a 94 318 dakota engine wiring harness with the same trans and be done, it is not hard at all to swap that harness plus you won't have to lengthen everything to reach the front sensors like engine coolant temps and alternator fields...
#2262747
03/03/17 05:18 PM
03/03/17 05:18 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
You really only need to add 2 injector driver wires to your existing harness for cylinders 7&8. The other wire is ASD power to the injectors is common to all of them. Just splice into the existing harness. Easy as pie. Use a 96 & up weighted 5.9 flexplate so no converter change is necessary. Just have to file one bolt hole a little to get the offset lug to bolt up. Trim your fan shroud and shorten your radiator hoses and everything else should fall together. Motor mounts are the same as well.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
#2263317
03/04/17 04:40 PM
03/04/17 04:40 PM
HotRodDave
Kalispell Mt.
The injectors from the 01 will not plug into any of the v6 injector plugs on your truck. You need to find 92-99 V8 injectors, the yellow ford ones are even better. All of your other sensors need to be swapped from the v6 as they changed most of them between those years, also your valve cover filler and breather holes are probably in the wrong places, they jumped around over the years and aplications. Is you donor engine from a dakota, durango or van? If it is from a ram it will need an oil pan and pickup tube swap (you can use the V6 pickup tube but not the pan).
[Re: HotRodDave]
#2263390
03/04/17 07:39 PM
03/04/17 07:39 PM
Posts: 2,046 ky.
kenworth_goose
ky.
The injectors from the 01 will not plug into any of the v6 injector plugs on your truck. You need to find 92-99 V8 injectors, the yellow ford ones are even better. All of your other sensors need to be swapped from the v6 as they changed most of them between those years, also your valve cover filler and breather holes are probably in the wrong places, they jumped around over the years and aplications. Is you donor engine from a dakota, durango or van? If it is from a ram it will need an oil pan and pickup tube swap (you can use the V6 pickup tube but not the pan). The engine is from An 01 Dakota
#2263400
03/04/17 08:16 PM
03/04/17 08:16 PM
HotRodDave
Kalispell Mt.
Then your pan will work, your injectors will not (without adapters or cutting and splicing all the plugs on it).
