Clunk in driveline #2263364
03/04/17 06:36 PM
03/04/17 06:36 PM
Illinois
Tinman761 Offline OP
Illinois
A little background. 67 coronet 500 3834bbl. Engine and trans rebuilt along with 323 suregrip and u joints. All done in 2010, by professionals, installed by me. Beginning of season last year I was noticing a clunk as it shifted through the gears, trans had a shift kit installed. Didn't give it much thought. Greased ujoints checked fluids all seemed good. Noise remains. This year weather was nice. Took it out and noise is worse. Checked diff fluid, low. Pulled third member out nothing out of ordinary found. Reinstalled with additive same problem. Pulled pan on tranny. Nothing but clean fluid. No debri in pan. Checked ujoints when shaft was out seemed ok no resistance found. All mountings seem tight. Worn but not moving. I'm out of things to check. I have a short video but not sure how to post if even possible. One thing I found today while running it was the driveshaft is extremely warm near the tail shaft of trans, but at the differential is cool. Help!
Re: Clunk in driveline [Re: Tinman761] #2263371
03/04/17 06:47 PM
03/04/17 06:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
could be a number of things as you know, but seeing you have some heat at the shaft front u joint, any binding/stiffness at the u joint-yoke when you had it out?...is it possible the driveshaft is too long/short?, how much fore to aft engagement of the yoke into/out of the tranny tail shaft/spline?, 3/4" is about ideal...how much spline of the yoke is in the tailshaft?
Re: Clunk in driveline [Re: Tinman761] #2263377
03/04/17 07:17 PM
03/04/17 07:17 PM
Illinois
Illinois
I thought about that, but I've had the car for about 10 years and haven't changed anything. I didn't notice the clunk until just recently. I didn't find any binding or resistance in the front or rear joints. It make the loudest noise when shifting to second gear around 20. Isn't is a duffle shift where second is a clunk and the drivetrain jerks
Re: Clunk in driveline [Re: Tinman761] #2263378
03/04/17 07:20 PM
03/04/17 07:20 PM
Illinois
Illinois
Just to add, when if first started it to check the new fluid, I didn't seem to feel it so I though it was the problem. But as it got warmed up it it was there.
Re: Clunk in driveline [Re: Tinman761] #2263388
03/04/17 07:38 PM
03/04/17 07:38 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Although you mentioned the front of the shaft was "heated/warm", may just be heat transfer from the tranny, exhaust?...
Have you looked at the converter/flexplate bolts, inspection cover for any signs of contact?
Sometimes we make changes that we think have no effect on problems, and neglect to mention them when asking for help, have you made any suspension mods? a different pinion yoke perhaps? transmission yoke change during the rebuild? I'll assume you checked the rubber tranny mount?
Re: Clunk in driveline [Re: Tinman761] #2263392
03/04/17 07:46 PM
03/04/17 07:46 PM
Illinois
Illinois
I haven't changed anything. I pulled of the inspection cover because I though I had a drain on the converter. Looks as clean as when installed.
Re: Clunk in driveline [Re: Tinman761] #2263430
03/04/17 09:27 PM
03/04/17 09:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you turn the driveshaft by hand to narrow down the location of the noise?
Did you try to push up on the rear of the trans to see if the mount is separating?
Did you look around the trans tunnel, fore and aft, to see if there are any witness marks? Do the same with the exhaust.
Inspect the rear suspension as it make be the source due to loading and unloading as you shift.
Don't be the exception.
Re: Clunk in driveline [Re: Tinman761] #2263450
03/04/17 10:15 PM
03/04/17 10:15 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Get someone to hang their head down low out of the passenger door to hear where it's coming from is my best suggestion, narrow the location down.
Sounds like a u-joint or a mount.. but could it be from an entirely different untouched part of the drivetrain? Anything like play at the drive axles, wheel bearings, anything like that?
Not sure I'd be too distracted by what's warm vs cool - both ends of my driveshaft definitely get warm during a drive.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Clunk in driveline [Re: Tinman761] #2263512
03/05/17 01:52 AM
03/05/17 01:52 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Don't overlook your motor mounts, especially the rubber biscuit mounts that came on the '67's. Here's the easy way to test them. Open your hood and start your engine, you should be able to see the engine or air cleaner through the gap between the raised hood and bottom of the windshield. Now put the trans in low gear and power brake the engine for just a few seconds. If your left side motor mount is bad you will see the left side of the engine raise up a good bit from the torque. Now do the same thing in reverse and watch the right side. I've seen them so bad the engine torques until the exhaust bangs off the floors. The rubber insulators will appear good until you put the torque to them, give it a try.
Re: Clunk in driveline [Re: Tinman761] #2263536
03/05/17 02:45 AM
03/05/17 02:45 AM
I would pull the shaft & check that the front yoke/ ujoint moves smoothly back & forth in both planes. pull the rear ujoint caps & how much end play the front yoke has into the trans (I like no more than 3/4"). extension housing rear bushing play. If all good I would swap in another pig (non sure grip/any ratio) what ever you have laying around to confirm/elim that. is the backlash OK on the one that is in there?
Re: Clunk in driveline [Re: Supercuda] #2263544
03/05/17 03:05 AM
03/05/17 03:05 AM
Illinois
Illinois
Driveshaft turns with no problem. Trans mount is good. No movement nothing seems to move except when it shifts second you can see the diff move as it clunks
Re: Clunk in driveline [Re: GODSCOUNTRY340] #2263545
03/05/17 03:08 AM
03/05/17 03:08 AM
Illinois
Illinois
Motor mounts are good replace them when I did the motor. Used Schumacher mounts.
Re: Clunk in driveline [Re: Tinman761] #2263546
03/05/17 03:11 AM
03/05/17 03:11 AM
Illinois
Illinois
I will pull it out again tomorrow and check. I really appreciate all of your ideas and suggestions everyone, I have a short video, can it be posted on moparts
Re: Clunk in driveline [Re: Tinman761] #2263550
03/05/17 03:30 AM
03/05/17 03:30 AM
Moves how? yes you can post a video (not sure how but others will help you).
Re: Clunk in driveline [Re: Tinman761] #2263584
03/05/17 11:12 AM
03/05/17 11:12 AM
Illinois
Illinois
I think if you could see it, it might help narrow it down
Re: Clunk in driveline [Re: Tinman761] #2263587
03/05/17 11:27 AM
03/05/17 11:27 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Try e mailing it to fmd@twc.com and I will see if I can post it for you if you want.
Re: Clunk in driveline [Re: Tinman761] #2263639
03/05/17 01:17 PM
03/05/17 01:17 PM
State of retirement
52savoy Online content
52savoy  Online Content
State of retirement
Did you check backlash on the rear-end? If the ring gear is set wrong or has a lot of wear it will clunk. You can do quick check by unbolting the driveshaft from the pinion yoke and see how much play is in the yoke. It should measure between .006 to .010
I'm getting a clunk on my D200 when it's put in reverse but haven't had a chance to look at it.
Ring and Pinion specs
Re: Clunk in driveline [Re: Tinman761] #2263846
03/05/17 06:08 PM
03/05/17 06:08 PM
Illinois
Illinois
Just a quick update. Pulled the driveshaft checked ujoints again. Small resistance but. Ow grinding found. Greased and reinstalled. While in neutral, rotating driveshaft back and forth I hear a clanking in the tail shaft section. I know the rear springs are worn so I put c clamps on the leafs to simulate load in the car while driving, but that didn't help( cars is off ground). I hear the clunk noise in the car on passenger side, and sometimes while shifting from drive to reverse.
Something else I just discovered, while rotating the passenger side wheel back and forth I get some play before the drive will turn and hear gears meshing? Drivers side is not so pronounced. Is this normal? Trans is in neutral
Re: Clunk in driveline [Re: Tinman761] #2263908
03/05/17 08:20 PM
03/05/17 08:20 PM
That is what Sherlock Holmes, Lieutenant Kenda and Columbo would (likely) call a (serious) clue(s). The clanking sounds real serious & I think that is what you are hearing when it shifts, if you can hear it now with what you are doing just imagine what is happening when the load is released on a shift. & thirdly the ujoints should move SMOOTHLY in there plane of travel (both ways in front yoke) back & forth.
Re: Clunk in driveline [Re: Tinman761] #2263928
03/05/17 08:51 PM
03/05/17 08:51 PM
Illinois
Illinois
I agree with you. So what would you do next? I'm at a standstill right now. Short of pulling the trans out and having it rebuilt or tore down to see if it's the prob. Or again pulling the third member out and have that looked at. Frustrating. Should you hear a gear noise when rotating the tire back and forth. Is it also normal to hear a noise out of the tail shaft area on the trans while rotating the shaft back and forth. Things I don't really have much experience with. Is it possible to post a video on moparts?
