83 D150 U-control arm dimensions? #2262094
03/02/17 10:49 AM
03/02/17 10:49 AM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Hi guys, trying to make my '83 D150 4spd shorty into a G-capable machine. What I'm looking for is some dimensions of the upper control arm. Shaft bolt spacing, length of control arm from shaft bolts to center of upper ball joint, B.J. angle if any etc..
Looking to source some aftermarket tubular's or fab my own if need be. Looking for adjustability and performance oriented geometry. Thanks, J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 83 D150 U-control arm dimensions? [Re: RAMM] #2262695
03/03/17 03:28 PM
03/03/17 03:28 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
There is a guy on Facebook, that builds upper and lower tubular control arms. He's in progress of developing a tubular front crossmember.
Re: 83 D150 U-control arm dimensions? [Re: wyldebill] #2262754
03/03/17 05:40 PM
03/03/17 05:40 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
I've seen his posts, looks like some nice stuff.
Re: 83 D150 U-control arm dimensions? [Re: wyldebill] #2263172
03/04/17 12:19 PM
03/04/17 12:19 PM
RAMM Offline OP
RAMM  Offline OP
Link please? Or name? Thanks, J.Rob
Re: 83 D150 U-control arm dimensions? [Re: RAMM] #2264106
03/06/17 01:06 AM
03/06/17 01:06 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Re: 83 D150 U-control arm dimensions? [Re: RAMM] #2264117
03/06/17 01:36 AM
03/06/17 01:36 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
That the ones. Is there a problem with his welds?
Re: 83 D150 U-control arm dimensions? [Re: RAMM] #2264462
03/06/17 07:11 PM
03/06/17 07:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
With no bracing towards the mounting ends, there will be a lot of load on the welds around the ball joint area and where the bushings press in on the mounting end. Gene
Re: 83 D150 U-control arm dimensions? [Re: RAMM] #2265424
03/08/17 05:42 AM
03/08/17 05:42 AM
mn
moparguy93 Offline
moparguy93  Offline
mn
Pm sent RAMM
