Moroso or Milodon ??360 oil pan for dart #226312
02/15/09 11:29 PM
02/15/09 11:29 PM
@ the shop
E
E-85 408 DART Offline OP
E
@ the shop
i like milodon (have ran before on bb)but,remeber some guys saying they run moroso because, the kick-outs on the milodon interfered w/headers .building new motor old headers are cheap hookers w/eddy head 4-speed probaly need to upgrade headers as well
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: Moroso or Milodon ??360 oil pan for dart [Re: E-85 408 DART] #226313
02/15/09 11:48 PM
02/15/09 11:48 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Moroso or Milodon ??360 oil pan for dart [Re: Ari440] #226314
02/16/09 12:01 AM
02/16/09 12:01 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
My Milodon pan hits the K member on my Duster. I've trimmed the Kmember as much as possible but the pan is almost touching it. I have to drop the motor in and then put the pan on. It is a real PITA. If I ever need a pan it will be a Moroso. I ran a Moroso pan on the 340 I had in the Duster and it fit perfectly. I sure wish I would have gotten a Moroso instead of the Milodon when I put the 360 in the car.
Raul
Re: Moroso or Milodon ??360 oil pan for dart [Re: Aspen7695] #226315
02/16/09 12:06 AM
02/16/09 12:06 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
the K frame is nocthed too on the pass side
1.39 9.85 - 137 mph
Re: Moroso or Milodon ??360 oil pan for dart [Re: Ari440] #226316
02/16/09 12:18 AM
02/16/09 12:18 AM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
Get a moroso if you can deal with the pan depth the milidon will require a big notch in the K-member and headder clearance is a big problem with some headders
Re: Moroso or Milodon ??360 oil pan for dart [Re: Ari440] #226317
02/16/09 12:38 AM
02/16/09 12:38 AM
@ the shop
E
E
@ the shop
anybody have a pic of the moroso i think the milodon hangs pretty low. what header are you guys runing ???
Re: Moroso or Milodon ??360 oil pan for dart [Re: W2DODGE] #226318
02/16/09 12:48 AM
02/16/09 12:48 AM
San Diego
formula S Offline
formula S  Offline
San Diego
We ran headman 1 7/8" w-2 headers and had to notch the k-member to get the engine in and take a hammer to the the pan to get the headers to fit. This is with a milodon pan, because of this I probably wont ever use a milodon pan again. it was a pain.
Re: Moroso or Milodon ??360 oil pan for dart [Re: formula S] #226319
02/16/09 01:18 AM
02/16/09 01:18 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Do the Moroso pans still have the drain plug on the bottom where it can be hit?
I used a Milodon wide-bottom like the one on Ari's car on my 406" street Duster; had to notch the K about 1" x 1", and for the headers, had to clearance the left rear corner at the bottom (widest part) about 1.5" x 1.5". But I think it's a better pan, becaue it holds more oil lower (away from the crank). I never scraped either the pan or the headers.
I've also had to notch the K on other cars with just a deep sump pan similar to the Moroso.
Re: Moroso or Milodon ??360 oil pan for dart [Re: topside] #226320
02/16/09 10:17 AM
02/16/09 10:17 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I ran a Milodon on my 340 with TTI headers with no issues, only the small notch in the k-member. My 408 will have one also but with the Heddman 1 7/8" headers it required some work. I already had the 360 pan or I'd looked at a Kevco (sp).
Re: Moroso or Milodon ??360 oil pan for dart [Re: Ari440] #226321
02/16/09 11:50 AM
02/16/09 11:50 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
I like the charlies pan. No problems what so ever. However, Mancini has this aluminum pan that looks good.
DC
http://us.st12.yimg.com/us.st.yimg.com/I/chucker54_2042_57441482
Re: Moroso or Milodon ??360 oil pan for dart [Re: dc426] #226322
02/16/09 12:57 PM
02/16/09 12:57 PM
Big Island ,VA
JC Childress Offline
Big Island ,VA
I have a brand new Charlies steel pan that I had built when I was gonna run Top Stock. Its a super nice pan. Its never been on an engine. I had it powdercoated black. It has a nice kickout, but hey....thats free horsepower ! I can email a pic if you want one. My email is brmbb74@aol.com
I'll take $300. for it ( way less than I payed ). Its for a 360. I have used pan for a 340 thats aluminum that I'll take $200. for if ya want it. Its also a Charlies pan.
J.C. Childress (434) 665-9541
Re: Moroso or Milodon ??360 oil pan for dart [Re: Ari440] #226323
02/16/09 01:11 PM
02/16/09 01:11 PM
Locomotion Offline
Locomotion  Offline
I'm using the Milodon 8 qt. because it is a bit shallower (but wider) than the Moroso and the coating is much nicer and much more durable. The K-frame notch on the passenger side should provide plenty of clearance if enough of the "lip" is cut out. It's about a 1 1/2" triangle and it doesn't cause me any intallation problems with the pan on.
The header clearance issues is not Milodon's fault. Most header manufacturers have a footnote on the issue. I know Hedman does and I found out the hard way long ago when trying to use their 1 7/8" headers. But I have been running TTI headers and they fit and work great. (Don't need a 90* oil adapter either!) I'm not sure if their newer 7qt. version clear the other headers or not. But it wouldn't hurt to call Milodon and/or the header manufacturers & ask.
The Moroso 360 pans still have the drain on the bottom and I ripped it out many years ago when a tire dropped off the pavement on a return road when giving room to a jr. dragster.
Re: Moroso or Milodon ??360 oil pan for dart [Re: JC Childress] #226324
02/16/09 01:26 PM
02/16/09 01:26 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Moroso, I have 2 of them one on my W2 motor and one on my broken 340. Both work good. I had the Milodom S/S pan years ago but got tired of taking the suspension apart every time I took the motor out and the other Milodon pan kicks out to far and would hit my headers.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Moroso or Milodon ??360 oil pan for dart [Re: 11secdart] #226325
02/16/09 05:07 PM
02/16/09 05:07 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I'm currently running the Kevko oil pan.. cheap, fits great and has built in windage and crank scraper..
http://www.kevko.net/
Re: Moroso or Milodon ??360 oil pan for dart [Re: Jeepmon] #226326
02/16/09 06:05 PM
02/16/09 06:05 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Which pan are you using? Did you have to use their pickup?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Moroso or Milodon ??360 oil pan for dart [Re: Jacob Pitt] #226327
02/16/09 06:13 PM
02/16/09 06:13 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I like the moroso 8 qt. Had it in my duster. No clearance probs at all. No cutting the k frame. I had 4 speed with tti headers.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Moroso or Milodon ??360 oil pan for dart [Re: Jeepmon] #226328
02/16/09 06:46 PM
02/16/09 06:46 PM
London, England
Gavin Offline
Gavin  Offline
London, England
I don't suppose you have a pic of the inside of that pan???
Re: Moroso or Milodon ??360 oil pan for dart [Re: Jeepmon] #226329
02/16/09 08:33 PM
02/16/09 08:33 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Which one are you running? I was going to run a charlies pan, but these are way cheaper.
Re: Moroso or Milodon ??360 oil pan for dart [Re: E-85 408 DART] #226330
02/16/09 08:36 PM
02/16/09 08:36 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Don't get me started on Milodon
Re: Moroso or Milodon ??360 oil pan for dart [Re: Jacob Pitt] #226331
02/17/09 12:05 AM
02/17/09 12:05 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Back when I bought my pan, they only offered one pan for the 360.. Now, I see they offer several different pans
The Pan I have is the M302.. and yes, you have to run their pickup tube.. M301-1
Here is a thread I created way back when I installed the pan..
https://board.moparts.org/ubbthreads/show...rue#Post4201108
