torque boxes--installing frame connectors #226273
02/15/09 10:43 PM
02/15/09 10:43 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Adding comp engineering frame connectors and have to cut the torque box's to weld the outside flange on,Do the torque box's become not an issue because i'm tieing the frames togather,In other words if i completely remove the torque box's does it matter-Steve
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: torque boxes--installing frame connectors [Re: swifter] #226274
02/15/09 10:46 PM
02/15/09 10:46 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Keeping the torque boxes will only help once the frame connectors are installed...
I have both...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: torque boxes--installing frame connectors [Re: swifter] #226275
02/16/09 12:07 AM
02/16/09 12:07 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
It matters. You want to keep the torque boxes and add the frame connectors. They both contribute to chassis strength. I would cut the frame connectors to fit the torque boxes rather than cut the torque boxes.
Re: torque boxes--installing frame connectors [Re: swifter] #226276
02/16/09 12:11 AM
02/16/09 12:11 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had to cut a slot in my torque boxes to slide the US Cartool subframe connectors up into place. Then I welded the subframe connectors and then welded the slot I had cut in the boxes to the connectors too. Here's a shot before I did any grinding to dress up the welds.
Later, I sealed all the welds with 50 year black roof and flashing caulking and coated the bottom with Resto Rick's undercoating. It looks a lot better now than it does in this pic.
Re: torque boxes--installing frame connectors [Re: jbc426] #226277
02/16/09 12:18 AM
02/16/09 12:18 AM
None
71rm23 Offline
71rm23  Offline
None
I want to install torque boxes and frame rail connectors as well. Can these be installed on a rotisserie? or a lift?
Re: torque boxes--installing frame connectors [Re: 71rm23] #226278
02/16/09 11:12 AM
02/16/09 11:12 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Tack everything in place while the car is supported on jack stands. This ensuresthe car stays in its static mode. You can then put it on a rotisserie or lift to do the final welding.
Re: torque boxes--installing frame connectors [Re: Stanton] #226279
02/18/09 05:17 AM
02/18/09 05:17 AM
None
71rm23 Offline
71rm23  Offline
None
Will there be a change in "static" if on jack stands? It would be difficult to tack weld everything in place even on stands.
Re: torque boxes--installing frame connectors [Re: 71rm23] #226280
02/18/09 12:38 PM
02/18/09 12:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It is a challenge to weld it while up on jack stands, on your back, with gravity pulling your molten puddle the opposite way you want it too, but it can be done. I used 12-ton jack stands under the front control arms and the rear end to simulate the resting load on the chassis. They allow the car to be raised pretty high up in the air. The stands were moved after welding/ undercoating in this pic, so I could finish undercoating the rest of the undercarrige. To the untrained eye, they now look like part of the original framework.
Re: torque boxes--installing frame connectors [Re: jbc426] #226281
02/18/09 12:44 PM
02/18/09 12:44 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Another view...
Re: torque boxes--installing frame connectors [Re: jbc426] #226282
02/18/09 12:45 PM
02/18/09 12:45 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
The final job on that looks great JBC426.
I welded t boxes and connectors in my Cuda a couple years back on my back. It sucked.
I now have a lift and it is wonderful. I am in the middle of doing the same to my Super Bee and it is a night and day difference. I actually LIKE to go out and work with it up in the air!
I think I'd like to seam seal my welds as you did JBC and try to get it a little less noticeable. I am painting the underside though, so it might be a little tougher to pull off. Heck, I don't know... the more I think about it, the more I think undercoating would just make my life easier. Don't ever have to worry about nicks under the Cuda, and it's nice.
Re: torque boxes--installing frame connectors [Re: PAINT IT BLACK] #226283
02/18/09 02:12 PM
02/18/09 02:12 PM
None
71rm23 Offline
71rm23  Offline
None
PAINT IT BLACK- When you welded your torgue boxes and connectors were you concerned about the body flexing before you welded? Maybe a body won't flex much if on a lift, but I think so.
Re: torque boxes--installing frame connectors [Re: PAINT IT BLACK] #226284
02/18/09 02:25 PM
02/18/09 02:25 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Thanks, sometimes I would just lie under the car and admire how beautiful the undercarrige came out....lol It's true. Now, if I can just get the top of the car to look as good, I'll be happy.
My main concern was to match the exsisting, sound factory undercoating as best I could. The 50 year black, paintable roof flashing and gutter sealer did fill some unsightly pits and holes in the weld seam as well as smooth out some less than perfect spots, but it was mainly to seal out water, sound and exhaust etc.
Resto Ricks undercoating and a Shultz gun allowed me to almost perfectly match the factory finish except where the factory stuff was really heavily oversprayed. Rick can match it perfectly, but he is the Master Blaster! His products and advice rock.
Re: torque boxes--installing frame connectors [Re: 71rm23] #226285
03/18/09 08:28 AM
03/18/09 08:28 AM
Houston Texas
Houston Texas
I know this was a while ago, but I stumbled on it in a search. I don't exactly know what you mean 71rm23... My car is on a level 4 post lift... so it is on all 4 wheels. The body is in its natural state, so no I am not worried about body flex at all.
Re: torque boxes--installing frame connectors [Re: PAINT IT BLACK] #226286
08/04/09 01:54 PM
08/04/09 01:54 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
You know all the subframes that don't weld to you floor pans(like Hotchkis)? The instructions are very adamant about welding them in with the car resting on all 4 tires. I wonder whats different about these laser cut ones where the US Car Tool's website shows it done on a rotisery. I wonder what the difference between the 2 is. I understand easier installation, but who cares about that if it doesn't function properly?
Just my 2 cents
BTW- I cant wait to get these on my Belvedere!
-1967 Belvedere II 440/4speed
Re: torque boxes--installing frame connectors [Re: MACDiesel] #226287
08/04/09 02:20 PM
08/04/09 02:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think common sense would dictate that ANY frame connector be tacked in while the car is in its normal stance. The rotisserie welding would then simplify and improve the final welding.
Re: torque boxes--installing frame connectors [Re: Stanton] #226288
08/04/09 02:33 PM
08/04/09 02:33 PM
st.charles,mo.
dodgem1 Offline
dodgem1  Offline
st.charles,mo.
just common sense
Re: torque boxes--installing frame connectors [Re: dodgem1] #226289
08/04/09 08:40 PM
08/04/09 08:40 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
I've always questioned that if you have frame sag in between the wheels if it wasn't better to raise the car in the middle a little bit and then weld in connectors. Perhaps more of an issue with convertibles? This is just my own idea on the subject, not sure if these cars actually have any sag or not, never actually tried measuring it yet.
Re: torque boxes--installing frame connectors [Re: lunacy] #226290
08/04/09 10:21 PM
08/04/09 10:21 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
My 69 GTX convert had some sag evidenced by a very tight door gap on the passagener side. When I unloaded the front suspension I pulled the gap out a bit so I welded by connectors in that way. I called US Car Tool and they confirmed this was the right thing to do.
Steve
