Leaf springs suggestions #2262433
03/03/17 01:03 AM
03/03/17 01:03 AM
Illinois
Tinman761 Offline OP
Illinois
I'm looking for replacement leaf springs and for my 67 coronet. I don't want to change the height or ride, just a stock spring. Thanks Joe
Re: Leaf springs suggestions [Re: Tinman761] #2262483
03/03/17 02:20 AM
03/03/17 02:20 AM
ESPO and springsnthings get good reviews on here regularly. An option would be to have your shop rearch the main leaf(s). You can clamp the springs out aways from the center bolt with a pair of C clamps then remove the nut on the bolt to seperate the leaves. I like to crack the nut with a nut cracker as the threads on the bolt tend to get messed up from road debris & I dont want to break the special bolt but your shop would have em on hand.
Re: Leaf springs suggestions [Re: RapidRobert] #2262548
03/03/17 09:54 AM
03/03/17 09:54 AM
Illinois
Illinois
Thanks Robert, I will check them out
Re: Leaf springs suggestions [Re: Tinman761] #2262690
03/03/17 03:19 PM
03/03/17 03:19 PM
dogdays Offline
dogdays  Offline
ESPO is SpringsNThings.
http://www.springsnthings.com/
The other supplier is Eaton Detroit Spring.
www.eatondetroitspring.com
Both have good reviews although both of them have their detractors. Funny how people are 100x more likely to complain than to give attaboys.
Detroit has blueprints for American cars going waaaaaay back.
R.
Re: Leaf springs suggestions [Re: dogdays] #2262895
03/03/17 10:03 PM
03/03/17 10:03 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Another good manufacturer Stanley (Harrisburg, Pa.) AFIAK they don't make make custom but Like Eaton/Detroit they have detailed info on many of the specific springs, many cross referenced to the original part numbers.
If you can't buy locally (call Stanley in Harrisburg for local retailers) Stengel Bros is a retailer that will ship to you. They have both a .net and .com website - don't know why.
Here's a direct link to Dodge leaf packs
http://www.stengelbros.net/Dodge-Passenger-Car-Leaf-Springs_c_194.html
Re: Leaf springs suggestions [Re: dogdays] #2262946
03/03/17 11:18 PM
03/03/17 11:18 PM
Oh OK
Re: Leaf springs suggestions [Re: Tinman761] #2262965
03/03/17 11:50 PM
03/03/17 11:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If yours artent broken look into having them rearched.Re did my kids 62 300 and had 1 inch extra lift an and extra leaf added.Better than any new springs you could buy.He ran them for at least 12 years and sold the car.Cost 100 bucks for both at the local spring shop.A good shop can do whatever you want.Rocky
Chrysler Firepower
Re: Leaf springs suggestions [Re: therocks] #2263078
03/04/17 02:46 AM
03/04/17 02:46 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thing is,
"A good shop can be hard to find today."
I have mechanical Aptitude.
I can screw up anything.
Re: Leaf springs suggestions [Re: bboogieart] #2263157
03/04/17 11:30 AM
03/04/17 11:30 AM
Illinois
Illinois
Thanks for the suggestions. Problem is there no good shops around me anymore
Re: Leaf springs suggestions [Re: Tinman761] #2263169
03/04/17 12:02 PM
03/04/17 12:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would suggest replacing the U bolts as well. The nuts use an interference fit that tend to deform the thread as they are tightened up. Reusing them aggravates the issue.
Don't be the exception.
Re: Leaf springs suggestions [Re: Supercuda] #2263179
03/04/17 12:29 PM
03/04/17 12:29 PM
I would highly suggest cracking the u bolt nuts with a nut cracker then removeing the nuts and clean the bolt threads with a thread chasing die & then the new nuts will go back on like butter (45 lbs on 1/2" ubolts). Road debris fubars the threads on the shanks over time. lightly Snug all 8 nuts evenly then tighten em so the axle lays flat.
