400 Big Block Carburetor Question #226247
02/15/09 10:36 PM
02/15/09 10:36 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Recently removed the factory Lean Burn Thermoquad off my 78 Cordoba. Replaced it with an Eddy 600.
Will this Eddy carb be adequate for the stock configured 400 Big Block?
Re: 400 Big Block Carburetor Question [Re: SPWC] #226248
02/15/09 10:54 PM
02/15/09 10:54 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Sure you may need to play w the mixture though to get optimum drivability and mileage.
Re: 400 Big Block Carburetor Question [Re: SPWC] #226249
02/15/09 11:19 PM
02/15/09 11:19 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Um.....WHY?!?!
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 400 Big Block Carburetor Question [Re: SPWC] #226250
02/15/09 11:33 PM
02/15/09 11:33 PM
will this Eddy carb be adequate for the stock configured 400 Big Block?
perfect size
Re: 400 Big Block Carburetor Question [Re: RapidRobert] #226251
02/16/09 12:25 AM
02/16/09 12:25 AM
SPWC Offline OP
SPWC  Offline OP
Um.....WHY?!?!
Because I replaced the Lean Burn Ignition with a standard Mopar Electronic ignition system and now the new Dizzy has a Vacuum Advance(The old Lean Burn Dizzy didnt) but the Carb had no place to hook the vacuum advance up to. Was told I could modify the baseplate,but that would require drilling and installing the vacuum port. Much easier to just put the carb on the engine and be done.
Re: 400 Big Block Carburetor Question [Re: SPWC] #226252
02/16/09 09:28 AM
02/16/09 09:28 AM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
Ah yes, I remember when I did the Lean Burn Thermoquad toss! I changed the intake also, but I was just a wee little lad who had been seduced and under Mothers spell! I am much better now-mostly.
600 sounds like a great size for a B-Body cruiser
Big Anthony ANTHONYinIRAQ@gmail.com
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: 400 Big Block Carburetor Question [Re: amixon] #226253
02/16/09 11:11 AM
02/16/09 11:11 AM
SPWC Offline OP
SPWC  Offline OP
I have 2 intakes laying around to choose from to install,but if I can get away with just a Carb adapter and carb,well its that much less work involved.
Re: 400 Big Block Carburetor Question [Re: SPWC] #226254
02/16/09 11:14 AM
02/16/09 11:14 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
That may be the case, but the Thermoquad would run better and would be better for the 400. It is very easy to add a ported vacuum source for the advance can. The AFB cant hold a candle to a properly tuned TQ
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: 400 Big Block Carburetor Question [Re: 69L78Nova] #226255
02/18/09 07:12 AM
02/18/09 07:12 AM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
I think any intake will work, just use that little thin edelbrock adapter (EDL-2732 6.95 from summit racing) to mate the AFB to where the spread bore thermoquad once sat.
I am not sure how saavy you are with tuning but the AFB style carb is SIMPLE, and since this isn't a hot rod, point and shoot is easy for a street car.
I would think if the Thermoquads were so awesome Carter or someone would still be producing and selling them-but what do I know?
1984 B150 Ram Wagon
1978 D100 ClubCab
