E brake cables #2262458
03/03/17 01:33 AM
03/03/17 01:33 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Who makes the most accurate reproduction e brake cables? I can tell you it's not Year One. They don't make the end that fits in the frame where it will accept a clip. It's just loosely stuck in the hole in the frame bracket.
Re: E brake cables [Re: fastmark] #2262475
03/03/17 02:05 AM
03/03/17 02:05 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have no experience with any of the reproduction cables. Perhaps just getting a nice original that is made right would be better?
I do know if you have a decent original cable you can clean it up by rolling it in a loop and putting it in the bottom of a paint bucket with Evaporust in it overnight. Mine looked like it needed to be tossed, but it came out great after I got all the surface rust off it.
Re: E brake cables [Re: fastmark] #2262573
03/03/17 11:33 AM
03/03/17 11:33 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I don't think any of them have truly correct ends on them or the firewall gasket.
Still you might want to check out fine lines.
Re: E brake cables [Re: fastmark] #2262622
03/03/17 01:16 PM
03/03/17 01:16 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
This is a customers car with rust stuck cables. I don't have any to sell from a spare rear housing.
