Re: Real world weight loss program and it` cost..........
[Re: hemi-itis]
#2259950
02/26/17 05:03 PM
02/26/17 05:03 PM
fullmetaljacket
A nice fine tooth jigsaw will do the trick. Cuts like a charm. Make sure to draw out your lines perfectly and stick masking tape along the edge where the cut will be so that the jigsaw does not mar or scratch the surface. A nice filing with a good flat file after that can take off the rough edges and or round 'em out just like the stock items. An important detail to consider when selecting glass thickness: When you have a post sedan door with its solid window frame, you can get away with as thin as 1/8 thickness glass because it always rides on the rails of the frame. It is snugged into place once the window is all the way up (closed position) and barely shakes depending on how aggressive the lobe of the cam is. More like a quite quiver which I think is pretty cool. It will at sometimes need a little guiding hand to get it to seat up in the rail channel up top during the closing. It will ride looser when it's down (opened) but not a bother at all. 3/8 thickness will be a little more forgiving and know its trajectory on the rails, but heavier. Now, if you are permanently attaching the glass (no up or down operation) and with no regulators, then you can save a whole lot of weight and quiver a little less.
[Re: Thumperdart]
#2259984
02/26/17 05:46 PM
02/26/17 05:46 PM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
I'm feeling a sharp pain in the,,,,,,,,,,,,,NECK...... I have seen this one black car that has poly in the thin version,I would want the thicker version.Is the rear/back hard to install?
[Re: Thumperdart]
#2262443
03/03/17 01:09 AM
03/03/17 01:09 AM
hemi-itis
That is one source,,,,,Ve hav rrrr vays,,,,,,,,,
[Re: hemi-itis]
#2262511
03/03/17 03:55 AM
03/03/17 03:55 AM
Thumperdart
State of confusion
Thinking about going to a rear glass bumper but not sure on it's strength and obviously I can't push it from there anymore but I'd guess 30+ lbs............
[Re: Thumperdart]
#2262652
03/03/17 02:12 PM
03/03/17 02:12 PM
hemi-itis
Nope,no pushin!! Play dope on a rope,,,,,,,,
[Re: Thumperdart]
#2265766
03/08/17 08:12 PM
03/08/17 08:12 PM
Posts: 200 Colorado
Bob J
Colorado
How much did the fender braces remove as I'm looking at them also.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Bob J]
#2265843
03/08/17 10:18 PM
03/08/17 10:18 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
How much did the fender braces remove as I'm looking at them also. The fender braces with the hardware that Jeff supplies was a weight loss of 11 ounces. MJ
[Re: moparjohn]
#2265977
03/09/17 01:52 AM
03/09/17 01:52 AM
fullmetaljacket
Picking away you. Those wiper covers must be the plastic types, since there are chrome metal types as well, but a little heavier by an ounce or two and enough to bump the scale. I find myself laughing at this, but this is some serious Voodoo science. Started on the Passenger side light alloy door today with "The Palm Reader" and his magic. I told him it doesn't have to be arrow straight since these were "Factory Hot Rod" parts and weren't perfect to begin with.
[Re: Thumperdart]
#2266139
03/09/17 12:31 PM
03/09/17 12:31 PM
hemi-itis
Hope to stop at the hardware store today.All the hardware that holds the fenders,grille,headlights,glass bumpers and antyhing else I can find in aluminum.Hope to get the car back in the shop to drop the empty block back in to mock up the headers,mid plate and measure up for a fab aluminum oil pan. Any guesses how much lighter an alum oil pan will be over the Miolodon?? My Milodon is so old the centerlink hole is round,,,,,,,
