Correct intake for a 1969 340?
#2262167
03/02/17 01:46 PM
03/02/17 01:46 PM
Posts: 2,270 St.Louis, MO
694406
St.Louis, MO
Is there a specific one (part #) more correct for a 1969 340? I have 2 intakes and one looks like a 1968 and the other a 1970. Thanks!
www.Musclemagnet.com1969 Cuda 383 Q5 1969 Cuda 340 4-spd Notch 1969 Cuda 383 4-spd Notch 1969 GTS Black on White 340 4-spd 1971 Cuda 383 V2, X9 Billboards, White Top!
Re: Correct intake for a 1969 340?
[Re: 694406]
#2262238
03/02/17 04:55 PM
03/02/17 04:55 PM
694406
St.Louis, MO
I have a 2531915. the resource I saw referred to it as 1968 and a 2531914 for 1968-1970?
[Re: 694406]
#2262280
03/02/17 06:44 PM
03/02/17 06:44 PM
Posts: 43,215 Bend,OR USA
Cab_Burge
The Mopar foundry, all of them, cast different parts with different casting numbers and casting dates for use through out the year My point is that the lower casting number will be made before the higher casting number for the same motor in the same year, especially if they have a mid year update or design change Look at your fender tag for the schedule production date and use the intake with the proper casting number that has a casting date before the SPD
[Re: 694406]
#2262379
03/02/17 11:17 PM
03/02/17 11:17 PM
694406
St.Louis, MO
[Re: 694406]
#2262417
03/03/17 12:40 AM
03/03/17 12:40 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have a original 340 intake I took off my 340 dart in the early 70's. I'll go out and see what numbers are on it.
[Re: 694406]
#2262429
03/03/17 12:58 AM
03/03/17 12:58 AM
rowin4
Well the date code on mine 12 11 9 the casting number is 3462849 1
[Re: rowin4]
#2262438
03/03/17 01:05 AM
03/03/17 01:05 AM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
That would be a 1970 intake.
JB Rhinehart, Realist
A-Body's RULE!
