Looking for a correct PCV & Brake booster check valve ? #226090
02/15/09 07:36 PM
02/15/09 07:36 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
Where's a good place to order a correct looking pcv and PB check valve, for a 70 Challenger 440-6. Thanks.
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226091
02/16/09 09:43 AM
02/16/09 09:43 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226092
02/16/09 11:37 AM
02/16/09 11:37 AM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Tom at RT has the PCV valve, but I'm not certain about booster valve. You might be able to get both from Badalson.
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226093
02/16/09 12:15 PM
02/16/09 12:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1970
http://amhightechauto.com/images/parts/70pcv.jpg
1971
http://amhightechauto.com/images/parts/PCV1.JPG
dont forget the grommet
and the gates hose
and the booster hose clamps http://amhightechauto.com/fuel-page.htm
correct power brake booster ck valve is NOS or used only , afaik
Re: Looking for a correct PCV & Brake booster check valve ? [Re: gtx6970] #226094
02/16/09 12:23 PM
02/16/09 12:23 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Show photo's of the correct bendix and midland booster check valves.
logan426
Re: Looking for a correct PCV & Brake booster check valve ? [Re: MLR426] #226095
02/16/09 12:31 PM
02/16/09 12:31 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Yes, that would be great if someone had a pic of what they should look like. I think I have the Midland (flat style?) booster.
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226096
02/17/09 09:31 PM
02/17/09 09:31 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
BTTP
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226097
02/17/09 09:32 PM
02/17/09 09:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
no promises but I'll see if I can get pics this weekend. I think A buddy of mine has a few nos ones
Re: Looking for a correct PCV & Brake booster check valve ? [Re: gtx6970] #226098
02/18/09 03:22 AM
02/18/09 03:22 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
3004625 Midland Check Valve
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Snoopy] #226099
02/18/09 03:30 AM
02/18/09 03:30 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Midland is Power Drum Brakes
Bendix is Power Disc Brakes
Re: Looking for a correct PCV & Brake booster check valve ? [Re: 1_WILD_RT] #226100
02/18/09 03:51 AM
02/18/09 03:51 AM
Snoopy Offline
Snoopy  Offline
List of brake booster valves.
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Snoopy] #226101
02/18/09 09:57 AM
02/18/09 09:57 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I have this one in Green that was on my hemi bendix booster.
logan426
Re: Looking for a correct PCV & Brake booster check valve ? [Re: 1_WILD_RT] #226102
02/18/09 01:10 PM
02/18/09 01:10 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
So then I must have a Bendix unit? The reason I ask is it is flatter (less depth) than most boosters I've seen. The check valve I have now has 2 vacuum nipples, one from the manifold and a smaller one that is capped off. Both of them are positioned perpendicular to the fitting that goes into the booster. (sorry, no pics).
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226103
02/18/09 02:58 PM
02/18/09 02:58 PM
Snoopy Offline
Snoopy  Offline
3420973 Check Valve
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Snoopy] #226104
02/18/09 03:14 PM
02/18/09 03:14 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
3420973 Check Valve
.OK, that's the one I have. Looks like mine is a Bendix then. I haven't checked it yet but I suspect that either it, or the booster itself is leaking. When you shut the engine off with your foot on the brake pedal it immediately loses vacuum. My experience has been that it should hold (at least for a bit) and/or give you about one more pump of the pedal before it's all gone.
Re: Looking for a correct PCV & Brake booster check valve ? [Re: Classof70Chally] #226105
02/18/09 03:38 PM
02/18/09 03:38 PM
Snoopy Offline
Snoopy  Offline
I think the originals were white and painted black.
