glide users step in #2260081
02/26/17 09:06 PM
02/26/17 09:06 PM
K
KOS Offline OP
KOS  Offline OP
K
looking to step up to a glide....i have a line on one that has the JWcase.the JW case looks huge compared to the reid ..anyone have any clearance issues putting one in using a factory ebody floorboard?also i need a bell ive heard the reid ones are setup for 1/4"midplate are the JW ones the same?i want to go with the least amount of hassle...i currently use 1/8"
Re: glide users step in [Re: KOS] #2260095
02/26/17 09:44 PM
02/26/17 09:44 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Im not sure about the physical size, but the jw case is way worse in quality.
I would look into the reid forsure.
Re: glide users step in [Re: KOS] #2260369
02/27/17 11:40 AM
02/27/17 11:40 AM
K
KOS Offline OP
KOS  Offline OP
K
yes i know reid is better the JW is local and would save me thousands just like to know about clearance issues and bell fitment.anyone else???
Re: glide users step in [Re: KOS] #2260521
02/27/17 03:02 PM
02/27/17 03:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have one in a a body fits fine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: glide users step in [Re: 1967dartgt] #2260662
02/27/17 07:59 PM
02/27/17 07:59 PM
K
KOS Offline OP
KOS  Offline OP
K
[quote=1967dartgt]I have one in a a body fits fine. [/q
what do you use for midplate? 1/4?JW bell?how was torque conv fitment?
Re: glide users step in [Re: KOS] #2260668
02/27/17 08:18 PM
02/27/17 08:18 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
The midplate dimension is all on the converter not the the Bell housing. You just have to make sure the converter manufacturer knows what midplate you are running.
My current set-up is a JW Bell to Mopar Block with 1/8" steel midplate JW Ultra Case, Continental Converter.
Re: glide users step in [Re: Biginchmopar] #2260695
02/27/17 09:27 PM
02/27/17 09:27 PM
K
KOS Offline OP
KOS  Offline OP
K
[quote=Biginchmopar]The midplate dimension is all on the converter not the the Bell housing. You just have to make sure the converter manufacturer knows what midplate you are running.
My current set-up is a JW Bell to Mopar Block with 1/8" steel midplate JW Ultra Case, Continental Converter. [/quot
thats what i thought but according to Hutch the reid case it is in the bell.guess ill just get a JW bell then..........
Re: glide users step in [Re: KOS] #2260710
02/27/17 09:50 PM
02/27/17 09:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I have run the JW stuff Case and bell in the Cuda for years with no issues. I now run ATI case in one car with a Mopar bell and a Reid case in the other. Converter manufacturer has just asked what mid plate dimentions are never the bell or case.
Re: glide users step in [Re: KOS] #2260744
02/27/17 10:54 PM
02/27/17 10:54 PM
K
KOS Offline OP
KOS  Offline OP
K
ok Al thx i just didnt want to get into any BS.
Re: glide users step in [Re: KOS] #2260747
02/27/17 10:56 PM
02/27/17 10:56 PM
crabman173
crabman173
JW case has had issues
Reid or ATI or Scummit case made by one of them is way to go--That JW is just plain ugly and they had all kinds of issues for a while so how do you know you aren't getting one of the "bad " cases
Re: glide users step in [Re: Al_Alguire] #2260753
02/27/17 11:03 PM
02/27/17 11:03 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
There are several variables.
Depending on whose stuff you use. Whether you want starter shims or not.
Originally mopar had the starter ring on converter. With JW wheel you have a crank adapter that spaces the flexplate out for proper converter clearance. By doing this the starter ring is closer to block requiring starter shims. They did not know how thick you needed due to midplates or not and sent a stack.
ATI makes their bell with their flexplate and crank spacer that also provides the 1.705" converter pilot.
REID made their bells in the beginning and offered flex plates with their sokution requiring no starter spacers. Customers switching from JW kits complained about the longer length so REID updated their bell shorter.
Their is two common ways to do this.
Use JW wheel and crank adapter with Reid bell then use JW starter shims.(I'm not in favor of this because it's a bandaid) A lot of big converter companies recommend this.
Use a standard a direct bolt in flexplate order converter with a larger mopar pilot or mopar to gm adapter and add JW starter shims.
With a 1/4" midplate covering starter pocket with Reid bell with the correct flexplate adapter you can use a standard height gm converter and everything fits.
I just removed a JW bell and trans. Installed Reid bell and trans. Used customers JW wheel and remade his crank adapter and a off the shelf standard height gm converter fits with .140" endplay.
So no REID's don't just bolt right up. ATI does, JW with the right combo of starter shims, and REID with the correct flexplate, crank spacer and starter spacer. I hate starter spacers so I have my way of accomplishing spacing that is just like my bellhousing kits for R5 nascar engines. But, you call your converter guy and tell him you have a midplate and you are screwed.
ATI and Reid are both great sources for bellhousings. BTE and QuickTime use Reid transmission patterns so I chose Reid when designing the R5 to aftermarket case. ATI T400 has both ati and reid boltpattern, for information.
Re: glide users step in [Re: ] #2260757
02/27/17 11:05 PM
02/27/17 11:05 PM
K
KOS Offline OP
KOS  Offline OP
K
if it wasnt coming from the person in question i would pass....he has used this particular case and is going to build it for me to my spex.if something falls through i will deffinately go with the reid.
Re: glide users step in [Re: KOS] #2260761
02/27/17 11:08 PM
02/27/17 11:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have had to shim the starter on all BUT the Reid case..So your mileage may vary.
I have also used the ATI and TCI midplate adapters and used GM Bells. IMO that is the best way to go for me. Allows me to be able to find a spare at the track when traveling as I quit carrying a spare with me.
Re: glide users step in [Re: Al_Alguire] #2260800
02/27/17 11:50 PM
02/27/17 11:50 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I have all ATI components. case, bell, tail shaft housing and ring gear. Everything just bolts up and fits as it should. 69 GTX 540 Hemi. low 9s @140
Re: glide users step in [Re: KOS] #2260817
02/28/17 12:26 AM
02/28/17 12:26 AM
K
KOS Offline OP
KOS  Offline OP
K
ok should i use the Reid bell with the JW case if i go that route?ATI sounds like a nice piece anyone have any pix?
Re: glide users step in [Re: KOS] #2260895
02/28/17 03:37 AM
02/28/17 03:37 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I think the starter thing depends on the flexplate used. I have a Meziere and the starter is a joke. Otherwise the Reid stuff is excellent.
Re: glide users step in [Re: KOS] #2261220
02/28/17 07:46 PM
02/28/17 07:46 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Do the afternarket bells bolt on a std pg case?
Re: glide users step in [Re: KOS] #2261277
02/28/17 09:11 PM
02/28/17 09:11 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Not sure on that but I think that they would...
Re: glide users step in [Re: Dave Hall] #2261326
02/28/17 10:50 PM
02/28/17 10:50 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Reid bells bolt to Reid and BTE cases. And with a reducer ring ATI t400.
They will not bolt directly to your JW case. JW bells bolt through pump bolts.
Reid and ATI have a seperate flange.
JW is no comparison to Reid or ATI. Reid has no internal sheild and the flange is heavier duty.
If your using a jw case this is all a wasted discussion
Re: glide users step in [Re: KOS] #2261392
03/01/17 12:09 AM
03/01/17 12:09 AM
K
KOS Offline OP
KOS  Offline OP
K
thx Leon.....looks like i have another option on the table a ATI proglide straight cut 1.80...watta you guys think?
