'76 D100 - Fuel Sending Unit Replacement #2260243
02/27/17 01:11 AM
02/27/17 01:11 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My fuel gauge is eternally reading low on my Warlock and I need to get that fixed as I will be daily driving it. I've changed out the cluster voltage regulator to a solid-state 5v, I am getting 5v to the sending unit and I made a new ground for the sending unit...no improvement.
1) What is the best way to access the unit? Pull the bed wood, or drop the tank?
2) What can I do for a sending unit? It seems like these are hard to come by, is this it? ***Link*** I am not sure what size my tank should be [short wheelbase, 360, 2wd].
Thanks!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2260500
02/27/17 02:29 PM
02/27/17 02:29 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
I say drop the tank - they almost always need cleaning anyway.
And yes that unit is pretty much the only out there right now Mother Mopar has not made them in a while.
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: '76 D100 - Fuel Sending Unit Replacement [Re: LilRed7879] #2260552
02/27/17 04:00 PM
02/27/17 04:00 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks, I'll start spraying down the hardware to remove the tank. The linked sending unit calls for a 18gal tank, for some reason I thought it was a 20.
2020 RAM 1500
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2260584
02/27/17 05:11 PM
02/27/17 05:11 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If the float is the problem go to Ford.They had ones for Vans sday like 98 or so.I had a bunch and they were some plastic that never went bad.I pulled at least 10 when I changed senders etc on them.used some and have no idea where I put the rest.Rocky
Chrysler Firepower
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2260708
02/27/17 09:43 PM
02/27/17 09:43 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
If you can find a NOS unit I would recommend it. I got mine from Len Dawson just a couple months ago for not much more then the repo. Part number is 4240277. If you remove the drive shaft you will have plenty of room to drop the tank.
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2260857
02/28/17 01:37 AM
02/28/17 01:37 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If the gauge is always reading low, it may not be a bad sending unit, the float could be bad, or the float arm could be out of adjustment. You need to pull the sending unit either way, but I think once its out, I would check to see if moving the arm results in the gauge reading properly.
Years ago, when I dealt with this stuff often, about 50% of the time, the float or float arm adjustment was the cause of a consistent high or consistent low reading. It the reading was all over the place, or would not function at all some times, the sending unit was often the issue. Gene
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2260950
02/28/17 11:20 AM
02/28/17 11:20 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks, I was wondering how frequently a float would fail. Somewhere I have the old sending unit from my Cuda that I could steal the float from. I may try that first, the gauge just constantly reads low. Full ~= 1/2 on the gauge.
2020 RAM 1500
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2261080
02/28/17 03:28 PM
02/28/17 03:28 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
sending unit in my truck was fine, i replaced the float with a brass ford float.
the factory gauge read way high.
i put an autometer gauge in it. been fine since...
Re: '76 D100 - Fuel Sending Unit Replacement [Re: GoodysGotaCuda] #2261189
02/28/17 07:02 PM
02/28/17 07:02 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
and while you have the tank off replace the front to rear brake line, and check the frame, the tank holds in a lot of crap in that area.
1981 Dodge D150 360 auto
