Brake pedal will not return...stays on floor #2260165
02/26/17 11:10 PM
02/26/17 11:10 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Hi
1969 Roadrunner, power drum brakes. New master, wheel cylinders, and hoses. Brakes will stop car just fine, but brake pedal will not come back up, keeping brakes applied, have to pull pedal up with your foot. Do not know the history on the car, a friend just bought it, drove off the trailer into shop for a cam change and said brake work.
Brake booster bad???
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260191
02/26/17 11:49 PM
02/26/17 11:49 PM
Andrewh Offline
Andrewh  Offline
does it do it with the car off as well, or only when you have vacuum on the booster?
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260200
02/26/17 11:59 PM
02/26/17 11:59 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By Lee
Hi
New master?...has the booster to master pushrod airgap been adjusted properly? you'll need .020 to .060 airgap
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260207
02/27/17 12:10 AM
02/27/17 12:10 AM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
with engine running, pedal stays on the floor, with engine off, pedal return about half way. removed and lubed pivot bolts under dash. No help. booster push rod was adjusted correctly.
Lee
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260217
02/27/17 12:30 AM
02/27/17 12:30 AM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
When I get a chance tomorrow, I will unbolt the master from the booster and see if it makes a difference.
Lee
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260247
02/27/17 01:16 AM
02/27/17 01:16 AM
thats my thought
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260293
02/27/17 02:37 AM
02/27/17 02:37 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
loosen the nut on the brake pedal rod where it goes thru the brake pedal..
Tony
70 AARCuda Vitamin C
Re: Brake pedal will not return...stays on floor [Re: 70AARcuda] #2260303
02/27/17 03:13 AM
02/27/17 03:13 AM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Did that.......
Lee
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260306
02/27/17 03:39 AM
02/27/17 03:39 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You might have to hone the piston in the master. If they sit long they tend to get funky in there and won't back out. Had it happen a couple times on my Mopar master I use for racing.
Re: Brake pedal will not return...stays on floor [Re: Lee] #2260307
02/27/17 03:39 AM
02/27/17 03:39 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Might be incorrect booster or defective booster. Had a similar problem with my 79 Warlock. Needed another booster. Problem solved.
