R5/P7+turbos=??????
#225931
02/15/09 05:00 PM
02/15/09 05:00 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
OK, so I haven't posted much about my project. Its a 67 Dodge D100 getting all late model '96 C4 Corvette suspension (dont bash, it was way cheap, or I'd run Viper stuff!!). I plan on running a Viper 6 speed trans, but have yet to decide on an engine combo, but it will be turbocharged. I have a std bore 69 340 block and some Eddy Magnum heads, but I don't want to blow stuff up. So I have been considering a 48 degree, siamese R3/W head combo but I just cant ignore how "cheap" the R5/P7 stuff still is. Any thoughts on how much boost the R5/P7's can handle? I'm most concerned with head gasket sealing, not block strength. Do the R5 blocks have a good sealing surface compared to an 18 bolt R3? Perhaps an XR block would be a better choice? Thoughts or opinions? Ryan?
Re: R5/P7+turbos=??????
[Re: The Avg. Valiant]
#225933
02/15/09 05:15 PM
02/15/09 05:15 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
From what I have read you will have to spend gobs of $$$$ for all the custom pieces that are required for the r5/p7 combo.....
The big question is how much power are you looking for.....standard r3 59 or 48 can make gobs of power when turbos are used.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: RyanJ]
#225935
02/15/09 05:22 PM
02/15/09 05:22 PM
Devilbrad
Pacifica, CA
Yeah the stuff is cheap, but how much power do you really need?
Biggest disadvantage to a turbo R5 deal is the lack of deck, it's a "jug" style block with no deck.
I just had my Coronet out again this afternoon & I'm not sure I'll ever own a car without a turbo again..... they're just brutal.
If I had it to do over again I'd just do a tall deck R3, with big inches & ICH heads with a single turbo. Unless you're going heads up/class racing, you can make some pretty big power with a turbo ICH setup.
Thanks Ryan, thats the info I was looking for. I was actually leaning towards some twin turbos for the "cool" factor. I also wouldnt mind bragging about 4 digit hp numbers, ha ha. Time to start searching for a 48 degree R3 block.
Rendering of the truck.
[Re: RyanJ]
#225937
02/15/09 05:33 PM
02/15/09 05:33 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Ryan you had your set up dynoed yet?
[Re: HotRodDave]
#225939
02/15/09 05:51 PM
02/15/09 05:51 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
No, the owner of the local chassis dyno does not want to run it for safety issues. I talked to him a few weeks ago & he said he just doesnt want to do anything that makes that kind of power anymore for fear of his safety standing there next to it.
I'm probably going to take it to Kauffman motorsports later this spring to dyno it after it's painted.
[Re: RyanJ]
#225940
02/15/09 07:19 PM
02/15/09 07:19 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Ryan, How much power can you throw at an R3 block before your pushing its limits? Are there tall and short deck R3's? And whats the advantage to doing a 48* motor when your using CNC -2's? Im no expert on the 48-59 degree differences/benefits....
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#225941
02/15/09 07:25 PM
02/15/09 07:25 PM
RyanJ
moparts member
moparts member
State College, PA
With billet caps, the blocks should be unbreakable.....
Yes there are short & tall decks. The one in my car is a short deck (9.0") Tall deck is 9.56".... Then there are 9.20" blocks. All short decks are Siamese..... Tall deck & 9.20's were/are available in both siamese & non.
Only real advantage of 48* is ability to drop in roller lifters with no work to block, & then better pushrod geometry. Most people who build ICH motors use 59 blocks, I've done both.... there are advantages & disadvantages.
[Re: Dos Snails]
#225944
02/16/09 09:44 AM
02/16/09 09:44 AM
RyanJ
moparts member
moparts member
State College, PA
Well Ryan, You need to make some deck plates like they make for the open deck honda stuff. I thought about a turbo r5 block before I bought a R3 but was sacred of the open deck. The honda guys use a open deck with a turbo so it will work.
AS I said, how much power do you really need? The 59* INDY stuff will support over 1000, the W8/9 stuff like I have will support ~1600+ with enough boost....
What are you really gaining by going to the P7 on a turbo app?
Why make life complicated, build a simple LA based motor unless you are going for every single last HP for heads up etc, & in that case I still would'nt use an R5 based platform due to short deck.
[Re: LA360]
#225946
02/16/09 08:17 PM
02/16/09 08:17 PM
Devilbrad
Pacifica, CA
What's the problem with the Short Deck????
AL....
Too hard to build a big inch low compression setup for turbocharging I'll assume. Pins would be all up in the ring lands.
[Re: Devilbrad]
#225947
02/17/09 08:31 AM
02/17/09 08:31 AM
Posts: 70 Finland
mopar396
Finland
Hi no turbos or R5/P7 but what do you think my engine what i am building?? R3 9.2" 48 degree W8 "lemans" heads Mopar billet crank 3.5" Carrillo 6.2" Ross racing 8.5:1 Steve Morris custom roller cam Procharger F3R C&S aerosol billet 900 tuned E-85
MOPAR OR NO CAR
[Re: LA360]
#225949
02/17/09 07:09 PM
02/17/09 07:09 PM
RyanJ
moparts member
moparts member
State College, PA
AL....
There has been no reference to an engine size, hence why I asked. If someone was looking at building a 400+ cube engine with Turbos I can understand the statement. If it was a 300-370 cube engine I would disagree. Boosted or not boosted, I'd want the shortest deck I could get away with. AL...
My motor is 3.58" stroke, & with a 9.0 Deck & a small chamber on the head, that is all the stroke I could run to keep the CR low enough for turbo. Mine's 394 inches..
If I had it to do again I'd have done a tall deck with at least 440 inches, so the motor was more responsive/had better TQ off boost down low & would'nt have to turn as much RPM. But I already had a brand new 9" R3 so... that's what I built.
That's why the large CC combustion chamber heads like an INDY have an advantage over something like my W9RP's with a 39 CC chamber... I could have ran hair more stroke if I had a bigger chamber even with the 9.0 deck.
[Re: RyanJ]
#225950
02/17/09 08:08 PM
02/17/09 08:08 PM
instigator
north cakalaky
So Ryan, how you like the feel of your new updated setup...been able to turn up the wick yet????
I'm finally getting my new heddars made up and hope to be up in about a month!
[Re: dart_73_br]
#225953
02/18/09 09:46 AM
02/18/09 09:46 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
One turbo fan more, although a big block. We are sitll learning things and started with relatively small turbos, 68.7mm. For next summer we may try a little more A/R, currently 1.22, but propably retain the current turbos. And new headers are about ready, moving the turbos rearwards and in to "clean" air. In my opinion, you don't need big displacement, you'll only get in to a trouble with all the torque. For example in our case, we have a stock 3.75" stroke and a PTC 10" converter that stalls at around 6500 rpm. Now, the engine hasn't been really turned much above that, but we got the stall speed down some 500 rpm by using SAE 80 oil in the trans. Despite of the early tuning stage, the engine produces good power on pump gas, and has pushed the C-body in to low 8 second ET's repeatedly. There is propably still way more potential left. http://www.kuvia.1g.fi/kuvat/Tapahtumat+2008/FHRA/KamasaTools/Pit/MOP_6762.jpghttp://www.kuvia.1g.fi/kuvat/Tapahtumat+2008/FHRA/KamasaTools/Pit/MOP_6763.jpghttp://www.kuvia.1g.fi/kuvat/Tapahtumat+2008/FHRA/DefaFinals29-31.8.2008/Defa29_31_08_1477.jpg
Plynouth VIP '67 TT IC EFI
[Re: dart_73_br]
#225955
02/18/09 11:47 AM
02/18/09 11:47 AM
RyanJ
moparts member
moparts member
State College, PA
Ok guys...
just for information...
How much for a combo like that !?
R3 block ? $$$ Heads for it ? $$$ Whatelse ?
Starndard SB camshaft and parts !?
For complete intake to pan motor with all new parts, figure $17K-$18K bare MINIMUM...
I added it up one day what it would cost if customer called & wanted me to build a duplicate of my engine it would be right at about $24,000 out the door. R3 block, billet caps, billet crank, Carrillo rods, Custom CP's, Solid roller 50MM cam, Crane Ultra Pro lifters, ATI damper, T&D rocker gear, & CNC heads, PSI springs, Ferrea Comp Plus valves, SM valve covers, MSD billet dist etc. & I could throw another $5-6K worth of stuff in there very quickly that I don't have on mine (crank trigger, external oil pump, custom oil pan etc)
[Re: theclutcher]
#225957
02/18/09 12:38 PM
02/18/09 12:38 PM
RyanJ
moparts member
moparts member
State College, PA
How much difference in torque are you talking about?
Is issue you see relative to street action or only a factor on track? Auto or manual trans?
For turbo street duty would think your combo would be more than enough with manual trans.
Street/strip car. Drag car does'nt necessarily matter, but if going for "all out" I'd still want decent amount of inches.
My car has a 727 & I could run less converter if I had more inches/stroke which would be nice for street use off boost, that's only real reason I'd do a big inch/big stroke deal if I did it again. Power up top is not an issue, that's only limited by how big of a turbo I run. I could put a 106 on it at 25+ PSI & make huge #'s if I wanted, but that would be a drag only piece.
[Re: RyanJ]
#225958
02/18/09 01:25 PM
02/18/09 01:25 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Horsepower is $$$
[Re: RyanJ]
#225959
02/23/09 08:36 AM
02/23/09 08:36 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
a new 48* Tall R3 is as close as your nearest MP dealer....
Are they finally available in a reliable quantity?
I ordered one in Feb-07 by Oct-07 they still were having issues with their Small Block Mfg. They said it would be at least another six months if everything went well.
I bought Leon's 468" shortly there after and canceled my order.
The guy at Mopar Performance told me to keep an eye out for the part number to change from AC to AD or higher, then they would be available again.
I did notice that change on Summits web page but they haven't been the most reliable for info like that.
I would like to have a 48* as a back-up to my 468" and a 59* to build using my Regular W-9's for a Street Dakota.
