Re: 1972 340 4-spd Demon 8.75 741 case inspection markings.
[Re: Barrelhouse]
#2259130
02/25/17 10:28 AM
02/25/17 10:28 AM
Posts: 892 MA
steve70
MA
I found this online. Your car should have a 489 case
8-3/4" 1820657 (small pinion shaft, up to 1964) 2070741 (small pinion shaft, 1965 to about 1972) 2070742 (large pinion shaft, 1957 to 1968) 2881489 (tapered pinion shaft, 1969 to about 1974)
1970 Challenger T/A 4 speed
[Re: steve70]
#2259196
02/25/17 12:36 PM
02/25/17 12:36 PM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes, find the date code, but it still could have had a 741 case.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Barrelhouse]
#2259200
02/25/17 12:39 PM
02/25/17 12:39 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Ron i also found code # D56 and # D83 on line 2 of the Broadcast sheet if that helps. The D56 comes up as 3.55 69-74 so I would guess I've had this wrong in my head all these years. I always thought the 741 ended years earlier. I guess because you probably have a small yoke 7260 u-joint they used this unit in a-bodies still. Sorry to steer you wrong. Ron
[Re: Barrelhouse]
#2262062
03/02/17 04:42 AM
03/02/17 04:42 AM
Posts: 19 Smithfield Virginia
Va58
Smithfield Virginia
Two 1972 340 Duster and both have 741 case. Both 3.23 gears, four speed is a sure grip.neither one gives me a reason to suspect not original..
