Trick Flow 270 intake and valley pan?
#2257739
02/22/17 01:35 PM
02/22/17 01:35 PM
Posts: 1,706 Nebraska
70VcodeCoronetRT
Nebraska
Hello, I have seen that the 270s are starting to show up in the real world. But have the intake and valley pan been released yet? Anyone have one? Thanks in advance
Re: Trick Flow 270 intake and valley pan?
[Re: AndyF]
#2258073
02/23/17 03:01 AM
02/23/17 03:01 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
They will have intakes for sure....
Brian Hafliger
[Re: Brian Hafliger]
#2258270
02/23/17 06:21 PM
02/23/17 06:21 PM
Posts: 31,073 Oregon
AndyF
They will have intakes for sure.... I hope so. I also hope they put EFI bungs in the new intakes and that they have a 4500 version with a well designed plenum. I'm going to be forced to run an Indy intake on my 470 with the new 270 heads and I'm not really a fan of the Indy 4500 intake. Edelbrock doesn't make a low deck Super Victor or else I'd use one of those.
[Re: RustyM]
#2258700
02/24/17 02:06 PM
02/24/17 02:06 PM
BradH
... They stated the intake for the 240 heads will be what they offer for the 270.
They indicated they left plenty of room to port match the existing intake to the new heads...
Having a hard time seeing same intake truly applicable.
I hope they come out with dedicated MW intakes. Expecting a standard-port intake to be effective on a MW head w/ only a simple port match job is... ummmm... looking for the right word... stupid.
[Re: BradH]
#2258714
02/24/17 02:23 PM
02/24/17 02:23 PM
AndyF
"Hello, Wilson Manifolds. I have another intake for you..." Maybe. I'd say that is plan C.
[Re: srunge55]
#2258870
02/24/17 06:47 PM
02/24/17 06:47 PM
AndyF
Andy since the Indy low deck intake seems to be the only option for the 270 head will you elaborate on why you are not a fan? Is it just the 4500 version or the 4150 also?
Just Curious, thanks,
Steve I just think the plenum on the 4500 intakes from Indy looks weird. The 3X might be an exception since those usually look like they actually belong there. But in the past the 440-3 and the 400-3 had very awkward looking plenums where it was clear that the casting was for a 4150 carb. Edelbrock has some 4500 intakes where the plenum looks really nice. The Mopar Performance M1 4500 intake look great. My guess is it was just a tooling expense thing for Indy.
[Re: 70VcodeCoronetRT]
#2258904
02/24/17 08:09 PM
02/24/17 08:09 PM
fast68plymouth
So. Burlington, Vt.
The fact is, regardless of how it looks, the Indy -3 manifolds are an easy 850hp piece in basically ootb form.
#2260071
02/26/17 08:45 PM
02/26/17 08:45 PM
AndyF
So can the current Trick flow intake be ported to match the 270 ports? Is there enough meat? Or is that a waste? Not really. There isn't enough material around the runners to make them a full MW size. The runners would need extensive welding to open them up to a full MW size.
#2260608
02/27/17 05:43 PM
02/27/17 05:43 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Has anyone got a 270 head to check out yet. Are the ports actually Max Wedge size, Being they are not running offset intake rockers. Based on my 240 heads, porting to max wedge height is no problem, but getting to max wedge width and a straight shot in without hitting the push rod channel is tough.
The only Carbs I care about are under the hood!
#2260610
02/27/17 05:49 PM
02/27/17 05:49 PM
fast68plymouth
So. Burlington, Vt.
They won't really have much more available width(if any)at the pinch than your current heads, since they both use the same(std) rockers.
[Re: fast68plymouth]
#2260624
02/27/17 06:13 PM
02/27/17 06:13 PM
Azzkikrcuda
North Dakota
Well at least I won't loose any sleep thinking I should have waited for the 270 heads as there probably little difference over my modded 240 heads.
