5.2 magnum interchange ? #2258154
02/23/17 12:34 PM
02/23/17 12:34 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Hello, im working on a 94 5.2 mag for my 87 d100 turbo build im in the process of rebuilding the mag engine.
Question is , I have a complete 318 la engine kit that I never used ,Just a basic kit gaskets,rings,bearings,oil pump,freeze plugs,etc ...will the la kit work in the mag engine ? or do i need a mag engine kit? also im going to use the la timing cover and acc as well .
Re: 5.2 magnum interchange ? [Re: 87MO DAK] #2258203
02/23/17 02:19 PM
02/23/17 02:19 PM
Andrewh Offline
Andrewh  Offline
there are a couple of gaskets I know are different. no idea on rings and bearings.
some of it depends.
Are you going with the LA front end?
the oil pan won't work and the gasket ends are wrong.
Re: 5.2 magnum interchange ? [Re: 87MO DAK] #2258216
02/23/17 03:06 PM
02/23/17 03:06 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Yes going to use the la front end,that's what I have.So should I use an LA oil pan ?
Re: 5.2 magnum interchange ? [Re: 87MO DAK] #2258242
02/23/17 04:04 PM
02/23/17 04:04 PM
Andrewh Offline
Andrewh  Offline
the 318 oil pan won't work.
the 5.2 uses the 5.9/ 360 pan.
You have to use the gasket for the pan you are using.
That is, if you use the mag pan, use mag gaskets.
assuming you can use a truck pan.
I mean I know you are putting it in a truck, I just don't know about that truck. I only do cars.
If you use a 360 pan, because you need to shift the sump, then you use the la gaskets for a 360. The end seals are different.
If you use the mag gasket on the la pan, the gaskets have a gap.
The la gaskets are too thick to fit on the mag pan.
Re: 5.2 magnum interchange ? [Re: Andrewh] #2258283
02/23/17 07:10 PM
02/23/17 07:10 PM
dogdays Offline
dogdays  Offline
I believe the ring package changed to narrower rings somewhere in there. So a generic LA ring probably won't work on a Mag piston.
RR.
Re: 5.2 magnum interchange ? [Re: 87MO DAK] #2258477
02/24/17 01:27 AM
02/24/17 01:27 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Head gaskets can be the same. Beware if using magnum gaskets in an LA, they may not have head oiling holes in them. La specific head gaskets are a non issue--I'm running fel pro 1008s on my magnum block, magnum eddy head motor.
Water pumps are different and use different gaskets.
Magnum thermostats are smaller, different gasket.
Most everything else is the same.
**Photobucket sucks**
