5.2 magnum interchange ?
#2258154
02/23/17 12:34 PM
02/23/17 12:34 PM
Posts: 115 NY,Poughkeepsie
87MO DAK
NY,Poughkeepsie
Hello, im working on a 94 5.2 mag for my 87 d100 turbo build im in the process of rebuilding the mag engine. Question is , I have a complete 318 la engine kit that I never used ,Just a basic kit gaskets,rings,bearings,oil pump,freeze plugs,etc ...will the la kit work in the mag engine ? or do i need a mag engine kit? also im going to use the la timing cover and acc as well . Thanks
Re: 5.2 magnum interchange ?
[Re: 87MO DAK]
#2258477
02/24/17 01:27 AM
02/24/17 01:27 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Head gaskets can be the same. Beware if using magnum gaskets in an LA, they may not have head oiling holes in them. La specific head gaskets are a non issue--I'm running fel pro 1008s on my magnum block, magnum eddy head motor.
Water pumps are different and use different gaskets.
Magnum thermostats are smaller, different gasket.
Most everything else is the same.
**Photobucket sucks**
