Who can CNC W2 heads? #2256215
02/19/17 08:48 PM
02/19/17 08:48 PM
Texas
Htownmopar Offline OP
Texas
Anyone know who can CNC W2 heads? There 15 degree valve angle, 48 degree revised port. P/N# P5007708AB
Re: Who can CNC W2 heads? [Re: Htownmopar] #2256225
02/19/17 09:01 PM
02/19/17 09:01 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I'd check with Brzezinski on any cast iron stuff.
262-246-8577
https://www.castheads.com/cylinder-heads/cylinder-head-porting-services/
S/F....Ken M
Re: Who can CNC W2 heads? [Re: Htownmopar] #2256231
02/19/17 09:14 PM
02/19/17 09:14 PM
Texas
Texas
Thanks, seems like there geared towards circle track racing. This will be a drag car application
Re: Who can CNC W2 heads? [Re: Htownmopar] #2256267
02/19/17 10:27 PM
02/19/17 10:27 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Try modern cylinder head. They don't have W2 listed as a CNC option but may well do it.
They don't have the eddies listed either, or W5, but know they do both of those
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Who can CNC W2 heads? [Re: B3422W5] #2256270
02/19/17 10:30 PM
02/19/17 10:30 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Brett Miller, send him a PM. I think he has dabbled in these.
Larry Meaux would be the other person I would speak with, does a lot of Super Stock stuff
Alan Jones
Re: Who can CNC W2 heads? [Re: LA360] #2256291
02/19/17 10:54 PM
02/19/17 10:54 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Brett Miller
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Who can CNC W2 heads? [Re: Htownmopar] #2256454
02/20/17 03:40 AM
02/20/17 03:40 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I had MCH do a set for me many years ago when Jeff was still around.
Floyd Lippencott IV
Re: Who can CNC W2 heads? [Re: Htownmopar] #2256456
02/20/17 03:47 AM
02/20/17 03:47 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Flow data.
Attached PDF document
Floyd Lippencott IV
Re: Who can CNC W2 heads? [Re: mr_340] #2256738
02/20/17 06:41 PM
02/20/17 06:41 PM
ccarson Offline
ccarson  Offline
W2 or not, That is strong for a cast iron head
Re: Who can CNC W2 heads? [Re: ccarson] #2256785
02/20/17 08:36 PM
02/20/17 08:36 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
Wonder what these ports in the heads Brett did the chambers on would flow like?
Howard
Re: Who can CNC W2 heads? [Re: Htownmopar] #2257765
02/22/17 03:07 PM
02/22/17 03:07 PM
warren, mich.
dwayne welder Offline
warren, mich.
Back in the day when I worked at Diamond Racing Engines Butch would make the intake port rectangular for the drag racing engines! The oval ports were for the circle track engines! Good luck
Re: Who can CNC W2 heads? [Re: dwayne welder] #2257780
02/22/17 03:33 PM
02/22/17 03:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I don't like the .300 lift numbers at all on that flow sheet. 179 @.300 is pathetic on a ported head. Especially on a head upgraded to a 2.08 intake valve.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who can CNC W2 heads? [Re: pittsburghracer] #2257787
02/22/17 03:49 PM
02/22/17 03:49 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I don't think it matters much what the head does at 300 on a race head. The early numbers go right out the exhaust port
Re: Who can CNC W2 heads? [Re: WHITEDART] #2257796
02/22/17 04:20 PM
02/22/17 04:20 PM
PA.
"Little"John
"Little"John
PA.
Keep in mind everyone doesn't run an .800 lift cam in their small block or shift at 8000 plus RPM.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Who can CNC W2 heads? [Re: Htownmopar] #2257806
02/22/17 04:45 PM
02/22/17 04:45 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
That was Jeff's first go on the ports. He worked on them a bit more to pick up the lower lifts. My W5 heads did flow better than the .300" number and that was as cast with a Ø2.06" BBC stock valve.
Floyd Lippencott IV
Re: Who can CNC W2 heads? [Re: pittsburghracer] #2257810
02/22/17 04:53 PM
02/22/17 04:53 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
they dont? Well who cares then 😜.. John I'm just poking👉 carry on
Re: Who can CNC W2 heads? [Re: pittsburghracer] #2257883
02/22/17 08:44 PM
02/22/17 08:44 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Slackers. stirthepot S/F....Ken M
Re: Who can CNC W2 heads? [Re: Htownmopar] #2257906
02/22/17 09:37 PM
02/22/17 09:37 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Most of my junk will blow apart long before 8000 or I'd do it. Haha
Re: Who can CNC W2 heads? [Re: killermopar] #2257915
02/22/17 10:01 PM
02/22/17 10:01 PM
PA.
"Little"John
"Little"John
PA.
Heck that's where that W8 and W9 stuff starts coming on. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Who can CNC W2 heads? [Re: pittsburghracer] #2257931
02/22/17 10:24 PM
02/22/17 10:24 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
you bet RPM is king..8000 is good 9000 is better💣
