Re: E body rally gauge question?
[Re: 72*Birdman]
#2252689
02/13/17 12:17 AM
02/13/17 12:17 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I am assuming that the gauge is hooked up to the sender now. I would suspect the tank ground or the sender is not connected at all. If you have an ohm meter, see if there is any resistance to ground on the green wire from the tank. Should see 8 ohms from a full tank or 70 for an empty tank and in between for anything else. All but the ammeter gets 5 volts from the regulator can. If the other water temp and oil pressure gauges are working and the black wire to the gas gauge is connected, the only thing it can be is the gauge itself or the tank wiring, the sender or the tank ground. To test the gauge itself is to ground the green wire with the ignition on and see if the gauge heads for full. If it does, unground it because it is not designed to pass that much current for long. I think grounding the frame is just coincidental with a sender issue. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 72*Birdman]
#2253310
02/14/17 01:15 AM
02/14/17 01:15 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
yes the ground strap is on Just for giggles run a ground wire from the sender to a good body ground. I've seen these fuel line grounds not work so hot
[Re: 72*Birdman]
#2253472
02/14/17 12:27 PM
02/14/17 12:27 PM
denfireguy
Colorado
the gas gauge itself is grounded to the gauge frame when its installed right? Could that be the problem? I just can't see how it could not be. I have an other gas gauge but am trying my best to not have to pull everything apart again to install it. I tried tightening the cap nuts on the gauge and they weren't bad and the metal piece that goes over the studs was also still in place, so I guess I'll dig out the OHM meter and see what that tells me. No. The gauge gets its ground from the fuel sender. There is a 5 volt regulator with the three wire spider that feeds voltage to the water temperature, oil pressure and gas gauges. That is working or the other gauges would be broken too. There is a green wire that goes from the gas gauge through the dash harness to a connector in the kick panel. That connector has the dome light, tail lights, backup lights, brake lights and the gas gauge sender wire. Just short that green wire to ground and see if the gauge goes towards full. If it does, keep going back to the sender in the tank. Short it in the trunk and check again. Craig
