Hemi Hyd Lifter RPM Limit #2256820
02/20/17 09:18 PM
02/20/17 09:18 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Just read that Ray Barton won't turn a Hemi over 6000 with Hyd lifters. Something about beating the push rod ends up. What do you all think?
Re: Hemi Hyd Lifter RPM Limit [Re: 71birdJ68] #2256837
02/20/17 09:54 PM
02/20/17 09:54 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
To much weight in those valvetrains for a juice lifter.
Mopar to the bone!!!
Re: Hemi Hyd Lifter RPM Limit [Re: 71birdJ68] #2256858
02/20/17 10:24 PM
02/20/17 10:24 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Ditto. I never use hydraulic lifters in a HEMI unless its strictly low RPM stock. Too much mass in the valve train.
Re: Hemi Hyd Lifter RPM Limit [Re: 71birdJ68] #2256926
02/21/17 12:34 AM
02/21/17 12:34 AM
Cab_Burge Online work
Cab_Burge  Online Work
I raced a 1970 Hemi 4 speed Cuda in NHRA stock, I shifted it at 7000 RPM with the anti pump up lifters that the original Racer Brown sold me, never had at issues with them confused
Is Ray Barton talking about hydraulic roller lifters maybe?
Re: Hemi Hyd Lifter RPM Limit [Re: Cab_Burge] #2256928
02/21/17 12:37 AM
02/21/17 12:37 AM
Morristown Tn.
Morristown Tn.
I don't know, it just said Hyd lifters. It is in the latest issue of Mopar Muscle, where he built them a 528 with his super stock valve train.
Re: Hemi Hyd Lifter RPM Limit [Re: 71birdJ68] #2258358
02/23/17 10:11 PM
02/23/17 10:11 PM
dogdays Offline
dogdays  Offline
Look at it like this: The Hemi has the longest pushrods and the largest rocker arms. The pushrods have to be quite beefy to withstand the sudden loads from valve opening. It probably uses a a pretty huge spring to control those behemoth valves. The piston in the hydraulic lifter has to withstand the accelerative forces of valve opening and closing. The more aggressive the cam lobe, the more the inertia loading that the hydraulic lifter sees. So is it going to leak down? pump up? oscillate?
The solid lifter has far less to go wrong and is probably lighter to boot.
R.
