I'm thinking of picking up a set,what are youre thoughts on these? are they hoakey or a good idea to run these?
Thanks!
If your referring to the inner bearing race sleeves for the 1 pc 73 and up rotors for use on the pre 73 spindles, utilizing the smaller 72 and down inner bearing, they will work just fine, if installed properly, I've turned my own down on a lathe many years ago to do this conversion...
You better check with Cass/DrDiff IIRC I don't think he makes those anymore, I could be mistaken?
