71 duster brakes ? #2256338
02/20/17 12:07 AM
02/20/17 12:07 AM
p.a.
420duster Offline OP
p.a.
Question ? Are the wilwood a direct bolt on ? If not .... what is needed besides kit ? Going on a 1971 340 duster,currently wearing factory KH disc brakes.Thanks !
Re: 71 duster brakes ? [Re: 420duster] #2259616
02/26/17 02:01 AM
02/26/17 02:01 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Are you wanting better brakes, and/or are you trying to switch to the larger bolt pattern?
It's possible to convert your KH setup to the 5x4-1/2 bolt pattern by having early mustang rotors machined for different wheel bearings and dust seals. Dirt cheap and you can leave the rest of your KH parts on the car.
Just looking at the Wilwood website and I only see disc brake kits to retrofit onto 65-72 oem drum spindles.
